Old 06-18-2015, 06:38 AM   #1
MMOHTASIB
Drives: 2008 yaris
Exclamation Error code U0105
Hi
I have Error code U0105 Lost Communication With Fuel Injector Control Module
my car is 2008 yaris sedan
any suggestions?
thanks
MMOHTASIB is offline   Reply With Quote
Old 06-18-2015, 07:57 PM   #2
That error is from the Power Steering ECU and indicates that it lost comm with the ECM.
If you have any devices that you regularly leave plugged into the diagnostic connector, the error could be due to that device squawking a bit too much on the CAN bus.
Old 08-01-2018, 10:01 PM   #3
ricardo-cr23
Drives: Toyota Yaris 2007 1.5L V4
Hi guys, I got the same error code in my car, but the P/S light never turned on, it does turn on at ignition which means the light is good.
I keep the diagnostic connector empty so that is not my issue. I have a BlueDriver OBD tool and it said that a common fix is to clean the battery contacts and replace the cable terminals. Will give a try.
Do you have any other suggestion?
ricardo-cr23 is offline   Reply With Quote
