02-10-2013, 07:19 AM | #19 |
Drives: 09 5dr LB, 2x 08 3dr LB Join Date: Oct 2008
That is correct - C15 is the 22 pin one on the bottom left.
02-10-2013, 10:08 AM | #20 |
Drives: Yaris Join Date: Jan 2011
Thanks for confirming that
02-20-2014, 12:46 PM | #21 |
Drives: Toyota Yaris Join Date: Feb 2014
Hi I am having same problem on 06 yaris display let me know how u get on
02-20-2014, 12:54 PM | #22 |
HI I got another speedo from a breakers and all seems ok
02-28-2014, 07:49 AM | #23 |
Does the surround to the speedo just pull off having a little problem taking off?
02-28-2014, 08:02 AM | #24 |
Yes.
03-04-2014, 09:25 PM | #25 |
Drives: 1999 1.0 gls 5dr Join Date: Sep 2012
I have had this same problem twice now, the first time i removed the electric ribbon that went to the speedo and replaced it with a second hand one which looked like new thinking it would last a few years but a couple of montha later the same thing happened again!
The speedo went off but the indicators kept working, the worst thing was the fuel gauge didnt work so even though i could use my phones gps to tell me my speed i just wasnt sure how much fuel i had left so i replaced the ribbon again and now it works fine but i dont know how long it will last. I blame condensation in the car for this problem as it has happened in winter. Replacing the filter behind the glovebox may help with condensation. I might try wrapping it in tape and laquering to make it waterproof. Anyway if you have the same symptoms try replacing the ribbon first! |
12-05-2018, 11:18 AM | #26 |
Drives: toyota yaris mk1 1.3 sol Join Date: Jan 2015
had exactly the same issue everyone is talking about.
sent the entire unit off to an electronics place...they fixed it and it worked for 3 years ish.....but now its back again :( |
Thread Tools | |
Display Modes | |
