Old 06-28-2016, 11:46 PM   #1
mekman
Drives: 2008 Yaris
Yaris Horn Relay
Hello - the horn on my 2008 Yaris has recently stopped working. checked the fuse, and it was blown, so I replaced it with the spare. The spare didn't work either - so I removed it, and saw that now the spare fuse was also blown. I replaced it again with another good fuse, tested the horn (no luck), and then noticed the third fuse had now also blown.
I've been reading to check the horn relay but haven't had any luck finding where the horn relay is in the fuse box. I've attached a picture of the fuse box - is the relay in this box or somewhere else in the car? The fuse for the horn was where the empty slot is in the top row of this picture.
Any help appreciated - thanks.
mekman is offline   Reply With Quote
Old 06-29-2016, 05:42 AM   #2
The horn relay is part of the integration relay, which is the chunk that the horn fuse is in.
Old 06-29-2016, 09:12 AM   #3
Bluevitz-rs
Bluevitz-rs's Avatar
Drives: '05 6-Spd Vitz RS
Sounds like you have a short in the system.
Old 06-29-2016, 01:56 PM   #4
mekman
Drives: 2008 Yaris
There's the image I meant to attach to the original message. So based on that first response, the horn relay is the long bar at the top with the three fuse slots in it?
Based on the horn not working and the fuse continuing to blow - does that sound to people like it may be the relay or something else? I'd hate to go buy a new relay only to find that's not the problem. Again any help/thoughts are appreciated. Thanks.
DIY Cruise Control FAQ (2006-2010 Yaris) CTScott DIY / Maintenance / Service 467 10-18-2022 10:20 AM
What is it about the Yaris Ranger SVO General Yaris / Vitz Discussion 18 01-06-2015 09:45 PM
DIY Cruise Control for 2012 European made Yaris CTScott DIY / Maintenance / Service 1 12-27-2011 06:47 AM
