Old 08-01-2015, 04:03 PM   #1
jack black
jack black's Avatar
Drives: 2007 red Yaris HB AT
heads up on the third brake light
it was not working. i googled and didn't find much on yaris, but some other toyotas had problems with dry solder inside. i took it apart and all components (4 LEDs, 2 resistors, and a diode) and connections were ok. i greased the connector with dielectric grease and it works now. all it needed was dielectric grease on the connector pins.
jack black is offline   Reply With Quote
Old 10-28-2015, 04:12 PM   #2
jack black
jack black's Avatar
funny how no one cared, LOL.
Old 10-28-2015, 08:24 PM   #3
Kar98
Drives: 2011 Scion tC
Every now and then I back up to a store front and check my lights for function. So far, the third brake light hasn't failed on mine yet.
Kar98 is offline   Reply With Quote
Old 02-11-2017, 12:51 PM   #4
jack black
jack black's Avatar
Well, the fix didn't stick for long. It had been off for quite a while. Anything else to try?
Old 02-12-2017, 04:08 PM   #5
SirDigby
Drives: 2007 yaris 3 door
can you test electric connections wile it's plugged in? check voltage before and after each component (LED, resistor, diode) and see where it stops. that will tell you where the issue is.
or you buy a new one: part #: 81570 52210
Old 02-12-2017, 09:50 PM   #6
jack black
jack black's Avatar
it must be intermittent as it worked today.
i also noticed to see it working during daytime, one has to be exactly behind, not much light shows up off center.
Old 02-13-2017, 09:23 PM   #7
SirDigby
there is one for sale in the market place for $10. cranky's clearance or something...
Old 02-14-2017, 09:09 AM   #8
jack black
jack black's Avatar
thanks, but what is the market place? I googled and sounds like it's a generic term.
Old 02-14-2017, 09:14 AM   #9
Marketplace is a forum here in which you will find the Items for Sale sub-forum.
Old 02-14-2017, 09:58 AM   #10
Bluevitz-rs
Bluevitz-rs's Avatar
Drives: '05 6-Spd Vitz RS
Marketplace
Old 02-14-2017, 12:37 PM   #11
http://www.yarisworld.com/forums/sho...54&postcount=1
Old 02-14-2017, 12:55 PM   #12
jack black
jack black's Avatar
thanks! i must be retarded, but couldn't find it myself. i searched for different word though.
too bad i didn't see it earlier. i got tailights from some asshole on ebay who didn't bother to ship it one week later.
ABS light on (without parking brake light) WildChild DIY / Maintenance / Service 15 05-06-2018 12:40 PM
2010 Yaris Replace 3rd (center) brake light waruna01 DIY / Maintenance / Service 5 05-13-2015 01:07 AM
Speedometer, brake light, odometer all gone weird boneyking DIY / Maintenance / Service 0 07-01-2014 01:30 AM
third brake light bulb fault Geoff Peace DIY / Maintenance / Service 4 06-29-2011 01:32 PM
Help Needed - Brake Light Question *MAD DOG* Cosmetic Modifications (Exterior/Interior) 21 02-08-2009 05:32 AM
