11-26-2008, 02:56 AM | #1 |
§†ęĄ¶‡Ћ-NCP96
Super Amazing Oil Change DIY
11-26-2008, 03:01 AM | #2 |
Drives: '08 Bayou Blue LB AT Join Date: Oct 2008
A+ for the DYI and the banana costume.
As for your photographer's focusing skills...
aFe Intake | Blitz Supercharger | Megan Header | TRD Exhaust | NST Pulley Set TRD Shocks/Struts | Tanabe NF210 Springs | TRD Sway Bar | Motegi TRAKLITE wheels | Kuhmo Ecsta XS R1 Concepts slotted rotors | Carbotech 1521 brake pads | stainless steel brake lines | Seibon vented carbon fiber hood |
11-26-2008, 01:30 PM | #3 | |
Shush!
now seeing as iv witnessed and assisted this oil change procedure.. now imma be cool and do my own too!
"Kids sure like the devil these days" |
11-26-2008, 01:56 PM | #4 |
Break'em off some.
One change I would make -
Make sure you break the oil filter loose BEFORE you drain the oil. You don't have to pull it off, just make sure you can turn it. That way if you have a problem getting it loose you can go get a proper tool and not be stranded. |
11-26-2008, 03:08 AM | #5 |
Dude...5 qts. is WAY too much. The car should only take 3.5-3.8 with a filter change. Overfilling with oil can do SERIOUS DAMAGE to your engine!
Good DIY otherwise! |
11-26-2008, 03:25 AM | #6 | |
Drives: 2008 Yaris Sedan Join Date: Oct 2008
11-26-2008, 09:21 AM | #7 |
Start another Oil Thread!
the "serious damage" is really just oil foaming.. because there's more oil in the sump, it's "sloshed" more by the crankshaft which keeps it foamy.. which means air bubbles are trying to lubricate the REST of your engine.. not very effective lubrication and very poor cooling properties
11-26-2008, 04:40 AM | #8 |
dry fill is no oil in the engine after a rebuild.......not an oil change with a filter. Also, a yaris is not a Honda. Do me a favor and take a look at the oil level on the dipstick and tell me how far above the high mark it is.
11-26-2008, 07:06 AM | #9 |
WFO
Drives: 2008 hb Join Date: Oct 2008
11-26-2008, 07:19 AM | #10 |
Drives: Absolutely Red Liftback Join Date: Aug 2006
11-26-2008, 04:53 AM | #11 |
I think it's 12 quarts before you can see the oil from the cap so why stop at 5?
11-26-2008, 09:12 PM | #12 | |
Drives: 2008 Yaris RS 4-Door LB Join Date: Oct 2008
On a serious note, wait for the oil to settle down (give it at least 10-15 minutes) after a drive and check your oil level carefully. Too much oil will cause your crankshaft to splash on the oil inside the crankcase and ..... create too much bubbles (like milk shake, eh) and consequently your engine lubrication will be compromised.
Benggolf2 |
11-26-2008, 07:58 AM | #13 |
Drives: Yaris Sedan (auto) Join Date: Jun 2007
Great pictures and effort on this DIY.
11-26-2008, 09:53 AM | #14 |
Drives: 2006 yaris Join Date: Oct 2008
I have always overfilled when prepping for a trackday since I did not run a baffled oil pan. This was on Hondas only but for the yaris I just do 4qts.
11-26-2008, 11:08 AM | #15 |
I'm not mad at the guy...I just don't want him to make a simple mistake and possible spin a main or rod bearing on a pretty much new engine in a great looking sedan.
06silveryaris, this last weekend I ran my oil level about halfway between full and low (about 3.2 qts. with filter at the change) on the dipstick, and never saw any fluctuation in oil pressure. Running too much oil, especially on the track, can lead to a dangerous loss of the oil's cooling and lubricating abilitys due to foaming (Thanks for elaborating Tomago). |
11-27-2008, 11:23 AM | #16 | |
never thought of that, I will def try it next time out. thanks |
11-26-2008, 12:21 PM | #17 |
Drives: '08 Yaris sedan , '08 Liftback Join Date: Oct 2008
otherwise well done . You should start your own show on the food channel . Oil and good 'ol HELPER are similiar . Just FUELS for thought .
11-26-2008, 06:44 PM | #18 |
Drives: 2009 Yaris liftback Join Date: Nov 2008
A few things I would change....
1) Engine and oil should be HOT to change the oil...don't let the car sit for an hour 2) Open the filler cap after you open the drain plug 3) Use wheel bearing grease to lube the filter gasket and spin on hand tight 4) I think that you let the car down before putting the drain plug back in. That's an important step. |
Similar Threads | ||||
Yaris Oil Change DIY | rningonfumes | DIY / Maintenance / Service | 91 | 01-11-2019 07:18 PM |
DIY: CHANGE MANUAL TRANNY OIL | ttufrosty | DIY / Maintenance / Service | 157 | 09-07-2018 01:43 PM |
DIY - oil change | kurokoma-kun | DIY / Maintenance / Service | 7 | 11-20-2008 12:12 PM |
DIY Oil Change | Bassmonkey | DIY / Maintenance / Service | 42 | 02-19-2007 08:37 PM |
Motor oil debate - interesting info but a long read. | mikeukrainetz | General Yaris / Vitz Discussion | 6 | 12-10-2006 08:16 PM |
