Old 11-17-2008, 08:41 PM   #1
auxmike
auxmike's Avatar
Best tool I've found so far to remove oil filter PICS
The black steel cap one from PepBoys is awful and hops a lot. The Channel Locks work, but there's not really enough room in that area so you have to tilt the pliers down and that makes it real hard to get a good solid grip. The AST is an all aluminum casting and fits like a glove!
Old 11-17-2008, 09:04 PM   #2
Thirty-Nine
Small cars are a big deal
Thirty-Nine's Avatar
I've got something very similar. It's plastic and fits a standard socket wrench. Works like a charm.
Old 11-18-2008, 04:13 PM   #3
stran
Drives: '07 Yaris 3D HB Auto
i use the walmart oil filter wrench and that works fine. it's the same design except plastic and costs $2.
stran is offline   Reply With Quote
Old 11-19-2008, 03:19 PM   #4
slvryaris
slvryaris's Avatar
Drives: 2007 Yaris Sedan S
I used one of these last time. I guess the torque spec on the filter is like screw on till it hits the top and then a 3/4 turn. The specs are in the service manual Thomas provided on here.
slvryaris is offline   Reply With Quote
Old 11-19-2008, 03:25 PM   #5
ROCKLAND TOYOTA
TRIM HUNTER
ROCKLAND TOYOTA's Avatar
nice to see it fits the newer cartridge ones as well.....
Old 11-19-2008, 06:24 PM   #6
bdc87
HISTORY REPEATED 11/04/08
bdc87's Avatar
Drives: 07' MM Vitz LB
Send a message via AIM to bdc87
I use K&N filters it has a "nut" built in so it can be directly removed with a wrench.
bdc87 is offline   Reply With Quote
Old 11-19-2008, 07:12 PM   #7
ToddR
Bacon!
ToddR's Avatar
Drives: 2008 Red Yaris LB
+1
ToddR is offline   Reply With Quote
Old 11-21-2008, 12:27 PM   #8
TheSilkySmooth
TheSilkySmooth's Avatar
Drives: 08 3DR 5M Bayou Blue; 09 Fos
I have plastic unit for a couple bucks for doing my sister's car, How much is this piece? Would be C-O-L-D in winter!
TheSilkySmooth is offline   Reply With Quote
Old 11-21-2008, 12:29 PM   #9
TheSilkySmooth
BTW any one find a good source for drain plug washers like under 25c each? No way I'm paying dealer a 1 euro for a penny washer. Can you use brass from the hardware store? and are they 12 or 14 mm? Sorry for all the questions.
Old 11-21-2008, 06:16 PM   #10
auxmike
auxmike's Avatar
About $20USD.
Old 11-21-2008, 06:19 PM   #11
auxmike
auxmike's Avatar
I splurged and bought 10 washers for $10 from the dealer.
Penny wise and Pound foolish can cost you a lot in the end.....
Old 11-21-2008, 06:25 PM   #12
Nexus1155
Bathroom + Laptop = <3
Drives: Audi
?????????? you know they sell this auto tightening chain wrench where you attach the links on the oil filter and then crank it... works on every one of our cars even when it is stuck on...
Old 11-21-2008, 09:49 PM   #13
pdarnell
pdarnell's Avatar
Drives: 2 door Liftback - Red, auto
Thanks for the info auxmike, I just ordered one from flatratetools.com for $14.00 and free shipping. I hope it works, changing the yaris filter has really been a pain in the as*.
PMD
pdarnell is offline   Reply With Quote
Old 11-22-2008, 07:00 AM   #14
nemelek
DWEED
nemelek's Avatar
The factory oil filter had more torque than 3/4 turn. I have found that 3/4 to 1 turn works well and I am able to remove the old filter by hand.
Old 11-22-2008, 08:07 AM   #15
Sodium Duck
╚══════════RN
Sodium Duck's Avatar
Drives: 2008 Liftback
Interesting, never seen that before.
Old 11-22-2008, 04:45 PM   #16
earljail
earljail's Avatar
Drives: 07 Yaris Hatch 5speed
Well, they are "crush" washers, so they are special. If you want to be cheap, just reuse them. I do replace it each time on my Yaris, but I didn't used to with the other cars I've had.
earljail is offline   Reply With Quote
Old 11-22-2008, 06:46 PM   #17
gid
Drives: '08 Yaris sedan , '08 Liftback
I use the black socket for changes . Take some sticky back felt and put on the inside edges of oil filter socket to help slide on and off the oil filter . That way shouldn't need to use claws of hammer to get stuck socket off of oil filter which can damage it . Once is on , I'll tighten by hand and then turn oil filter with socket about 3/4 of a turn . Last , I pour 4 ounces of oil into new filter before reinstalling . The TOYO ( Denso ) oil filters already have a lubricant ( looks like vaseline ) on gasket . A good thing , no oily fingers .
gid is offline   Reply With Quote
Old 11-23-2008, 11:04 AM   #18
Shroomster
'07 to '12:2 wipers to 1?
Shroomster's Avatar
just add little cutting wheels to the chain links and you have exhaust pipe cutters!!!
What about the oil filter???? Driver DIY / Maintenance / Service 28 10-23-2008 11:45 PM
Compiled 1NZFE Used Oil Analysis craigq DIY / Maintenance / Service 7 09-10-2007 04:27 PM
oil and oil filter question.. marcus DIY / Maintenance / Service 27 07-11-2007 03:25 PM
Toyota oil filter difference in sizes? pics Ogredude DIY / Maintenance / Service 7 04-02-2007 01:16 PM
Motor oil debate - interesting info but a long read. mikeukrainetz General Yaris / Vitz Discussion 6 12-10-2006 08:16 PM
