Old 08-31-2017, 07:50 AM   #19
ncp13
ncp13's Avatar
Drives: 01 Yaris TS
The install is complete.!
I used a Gates 6PK1678 belt that fits corolla 120 3zz and made a 4 rib belt. 12e. It comes also in 6PK1670 which I think will be my next try because I get a squeal at 5500rpm
Today I got a P0171 .
I checked for vacuum leaks.. nothing..
Long term fuel trim 30 at idle 0 coast -7 when I floor it..
My injectors are 23250-21020 stock 1nz I assume. My fuel pressure was checked before the instalation and the injetor o-rings replaced during the install..
ncp13 is offline   Reply With Quote
Old 09-04-2017, 01:20 PM   #20
ncp13
ncp13's Avatar
Drives: 01 Yaris TS
Small update..
Vacuum leaks and more vacuum leaks.
The previous owner had thick permanite compressor gaskets made and i made copies with the same material... Bad move .. The material is too thick .
Made some new ones myself with gasket paper and will install tomorrow. ..
Should i cut off that damn aluminum c section on the valve cover that protects the fuel rail? Its in the way
Old 09-06-2017, 04:15 AM   #21
ncp13
ncp13's Avatar
Drives: 01 Yaris TS
Vacuum leaks fixed with Toyota Black seal packing and no gaskets..
I tried the paper ones I made without luck.. and then the seal packing came to the rescue .. I am up to 5 times R/R the charger unit.. Dam..
I am getting good at it.
Now of to find a good belt as the Gates 6PK1678 at full tension squeals.
I will try their 1670 or maybe source a 4PK1675 if I am lucky.
Old 09-11-2017, 02:58 AM   #22
ncp13
ncp13's Avatar
Drives: 01 Yaris TS
Update on the belt slip.
I tighten about a turn at a time until I have a minor squeal at about 6100 which is fine for me.. I will leave it at that .
The 6PK1670 at the current adjustment leaves aboout 15mm on the bottom of the tensioner bolt so there is still some adjustment left. I will search for a 1665 lenght belt and see :)
The power is pretty linear with a flat spot around 5200 rpm and then a hard pull till redline. I have to datalog a few runs and attach a boost gauge to see whats going on .
Also there is a hessitation if the kompressor gets activated with the engine cold . I have to datalog that too..
I am still with the stock spark plugs, I will try the 20 range and see.
Old 09-13-2017, 04:22 AM   #23
ncp13
ncp13's Avatar
Drives: 01 Yaris TS
Did the colder spark plugs.
I reset the ECU and the car felt more responsive.. hmm
I installed the blitz timer boost gauge contraption that came with the kit and I verified 0.52 hkPa which is around 7.2 psi.. cool.. I hate the looks of that dam little thing and its coming off.. I did not care for the timer either..
Any tips or advice ?
Old 09-13-2017, 10:25 AM   #24
MugenRep
iQ innovator & researcher
MugenRep's Avatar
Drives: 2012 iQ
Love all the updates! Keep them up!
MugenRep is offline   Reply With Quote
Old 09-14-2017, 06:37 AM   #25
ncp13
ncp13's Avatar
Drives: 01 Yaris TS
Update
Yesterday taking off from low rpm and getting on boost I heard a little pinging..
It was 36C outside temp and just got off the highway. Regular 95 octane fuel was used..
Should I try the 22 heat range spark plugs?
Old 11-08-2017, 07:49 AM   #26
ncp13
ncp13's Avatar
Drives: 01 Yaris TS
Boost weather finally here
Finally we got turbo weather here in Greece.
8C at night 15C during the day..
The car is super responsive.. I cant convince myself to do the blue emanage yet.
It does feel restricted at high rpms. (stock intake, exhaust etc..) and then it sqeels at about 6k rpm..
I want to find 6 rib pulleys for my Ac/wp/crank/Blitz compressor to do away with the sqeal . Does anybody know of any models that I can get the from? ex Camry , avalon etc?
Old 11-08-2017, 11:18 AM   #27
CrankyOldMan
2ZR swap. DO IT! Ask how!
CrankyOldMan's Avatar
The problem you will have is finding a pulley for the compressor. It uses a spline connection instead of the more common taper and key style. I was never able to find one that would fit, so you might have to make something custom.
It's definitely restricted by the stock exhaust. Even with a CAI, 1ZZ throttle body and custom intake plumbing mine would die off above ~5500. Belt squeal is only controllable by tightening the accessory belt, but that puts extra strain on your bearings/pulleys on the accessory loop and can shear off the bolt on the far side of the intake plenum. Yes, I broke pretty much all of those things on mine.
Old 11-18-2017, 06:18 AM   #28
ncp13
ncp13's Avatar
Drives: 01 Yaris TS
For the compressor inguess i have to find another ac/clutch pulley for 6 rib..
I will try to free up cat and the rest of the system but with somthing quiet .. I hate unecessary noise polution .. I guess i am getting old and cranky too
Old 11-18-2017, 03:19 PM   #29
Drives: 04 echo RS
Use 1zzfe injectors if you aren't already
List of Boosted Yarisworld Members whooppee777 Forced Induction Forum 261 09-26-2017 09:18 PM
2008 vitzRs clone+fixed pulley blitz... blacksandiegovitz Forced Induction Forum 5 12-05-2010 02:26 PM
Blitz throttle controller 808_Yaris Performance Modifications 43 10-22-2009 04:36 AM
BLITZ HAS CLOSED????? ROCKLAND TOYOTA General Yaris / Vitz Discussion 12 08-13-2009 05:35 AM
GI: OFFICIAL BLITZ YARIS laszlo Cars for Sale by private party 11 11-25-2008 06:05 AM
Powered by vBulletin® Version 3.8.0
Copyright ©2000 - 2017, Jelsoft Enterprises Ltd.
