11-21-2017, 08:58 AM | #1 |
Tw200--excellent!
Drives: 2010 yaris..absolutely red. Join Date: Jun 2010
Window horizontal rubber piece replacement
2010 Yaris sedan hatchback. Driverside window rubber piece that runs horizontally on window sil ; hence , if your window was all the way down and your arm was resting on the door, your arm would be contacting this rubber piece I'm trying to describe. What's the difficulty in replacing this piece, mine has torn?. TIA
11-21-2017, 04:49 PM | #2 |
11-21-2017, 07:47 PM | #3 |
Tw200--excellent!
Wee Yaris , THANK YOU. Strange name for this part however , no wonder I could find anything about it. Generally it just snaps apart and new one snaps in......correct. TIA
11-21-2017, 11:13 PM | #4 |
Tw200--excellent!
Wee Yari. In time I'll have to replace a marker light or two. Any links on the front grill / bumper pins . I would like to have additional pins incase I break some of them while taking apart the grill area when replacing bulbs TIA
11-21-2017, 11:14 PM | #5 |
Tw200--excellent!
Sorry for the small print , not sure why that happened
11-22-2017, 08:28 AM | #6 |
Are you referring to the little football shaped lights on the fender above the wheel? If so, you don't need to take anything apart to remove them.
11-22-2017, 12:25 PM | #7 |
Tw200--excellent!
No. The marker lights within the headlight assembly.
So the front of the car has to be disassembled. Thats why ill need the anchors / pins for reassembly , I'm sure I'll break a few. |
11-25-2017, 10:06 PM | #8 |
Tw200--excellent!
Do folks order the push pins / anchors for the body work , hence front bumper area, from Toyota or where? TIA
Thread Tools | |
Display Modes | |
Similar Threads | ||||
Yaris Verso: Reset power window jam protection | togo | DIY / Maintenance / Service | 3 | 01-10-2013 10:03 AM |
Electronic Window Closer mod | cali yaris | In Car Entertainment + Electronics (audio / video / alarm) | 8 | 11-11-2011 11:16 AM |
Help: Rear Door Small Window Install | nick.dollimount | DIY / Maintenance / Service | 7 | 09-22-2010 02:22 PM |
Driver window replacement | EtienneGignac | General Yaris / Vitz Discussion | 0 | 06-20-2010 02:26 PM |
Front window replacement cost | jambo101 | DIY / Maintenance / Service | 7 | 06-11-2009 11:07 PM |
