Old 09-10-2016, 02:09 PM   #1
Craig W
Drives: 2007 Yaris S Sedan
I'm getting ready to install My mostly rebuilt manual trans
I pulled the transmission because the synchros are going bad I toke it to a trans shop and the clutch was sometimes chattering and just starting to slip so I had the flywheel resurfaced the clutch looked ok butt I'm thinking the spring plate got weak I was reading that the flywheel bolts are a stretch bolts so i ordered new bolts butt i think I've seen different torque specs to reinstall them I've seen the axle nut torque is 160 ft lb I was wondering if there are any other torque nuts or bolts I need to know
2007 Yaris sedan s manual 5 speed silver
2014 Tundra TRD off road double cab 5.7 blue ribbon metallic
Craig W is offline   Reply With Quote
Old 09-10-2016, 10:01 PM   #2
CrankyOldMan
2ZR swap. DO IT! Ask how!
CrankyOldMan's Avatar
The flywheel bolts are indeed stretch bolts: 38 ft-lbs, then 90°. Technically, all bolts have a torque spec. I followed the repair manual for my R&R.
Old 09-10-2016, 11:33 PM   #3
Craig W
Is there a link to a repair manual that steal works. I've had a hard time finding good links.
Yarisworld.com DIY Manual v3 vodkalush DIY / Maintenance / Service 100 12-13-2022 05:55 AM
manual trans fluid d2dailly DIY / Maintenance / Service 65 02-14-2009 07:38 AM
Want opinions automatic vs. manual transmission anik New YARIS Purchase Forum 84 07-10-2007 04:25 PM
Yarisworld.com DIY Manual v3 vodkalush Downloads for Registered Members 30 01-21-2007 10:54 PM
