Old 06-13-2018, 01:15 AM   #1
RicStyx
Drives: 2012 Toyota Yaris 1.3 -3rd Gen
Heated seats.
2012 1.3 French build.
On a previous thread it was brought to my attention that possibly my car had heated seats. Upon that I checked the fuse box and there was a fuse in place for the heated seats and a possible unknown connection in the center console.
What I need help with is the part number for the heated seat switch. It sits below the handbrake and is a basic on and off rocker switch for the front seats. And secondly if someone has this function, if they could take a photo of the switch with its connection to help confirm.
Sent from my SM-N910F using Tapatalk
RicStyx is offline   Reply With Quote
Old 06-13-2018, 09:52 AM   #2
stykerdk
Yaris Hybrid Limited 2015
Drives: yaris Hybrid limited 2015
Part number 84751-0D040
https://photos.app.goo.gl/AJ1avFFbNMKej86g6
Yaris 1,33 T2 Touch 2013
stykerdk is offline   Reply With Quote
Old 06-13-2018, 10:40 AM   #3
hotracer_05
Hmm, I see...
hotracer_05's Avatar
Drives: 2012 Toyota Tundra and Yaris
I would double check to see if a seperate control module is needed as well. On a lot vehicles its easier to just add aftermarket seat heaters than it is to add factory ones
"Everything happens for a reason. Sometimes that reason is you're and idiot"
hotracer_05 is offline   Reply With Quote
Old 06-13-2018, 02:05 PM   #4
RicStyx
Thank you. Upon closer inspection of the switch it seems it is not the heated seat swith that I have, as I can't find any black connector. However the only other ones that would be there is a auto on and off which I don't have and a sport button which it could be, luckily I have a Rav4 where I can take one out of and test it to see if its the right one.
Old 06-14-2018, 12:57 PM   #5
DarkShadowFox
DarkShadowFox's Avatar
Drives: 2015 Yaris LE 3door HB
cool. i was going to go corolla style and add two seperate heated seat functions. w/ hi and lo
Checkout My Build Thread: https://yarisworld.com/forums/showthread.php?t=58963
Im autistic about 3rd gen yarises. ask me anything.
Old 08-01-2018, 03:33 PM   #6
HDTechVideo
Drives: Yaris MK3 1.33L Dual VVT-i CVT
Im just wondering which year they started put heated seat on yaris. Mine is 2013, do I have to change the whole seat to make it a heated seat. Or is it already on it?
HDTechVideo is offline   Reply With Quote
Old 08-01-2018, 04:30 PM   #7
DarkShadowFox
they pull the cover off and STICK pads on and run wires. most heated seats work that way. ventilated/ cooled seats are just a fancy blower motor.
Old 08-01-2018, 05:30 PM   #8
HDTechVideo
Oh Ok so it is not pre installed in any model.
Old 08-03-2018, 04:05 PM   #9
DarkShadowFox
no cause it would outclass the corolla/ be expensive. I think their installed in extreme climates like canada but its not standard its still a third party.
Old 08-05-2018, 01:58 PM   #10
HDTechVideo
Hi what is this connections for? Is that for heating?20180805_185553.jpeg20180805_185600.jpeg
Sent from my SM-G935F using Tapatalk
Old 08-06-2018, 08:55 AM   #11
DarkShadowFox
Hi what is this connections for? Is that for heating?Attachment 59805Attachment 59806
do you have the VSC trac off button installed?
Old 08-06-2018, 12:44 PM   #12
HDTechVideo
DIY: Heated Seats for 2006-2011 Yaris CTScott DIY / Maintenance / Service 24 11-04-2012 06:18 PM
snow tires, steelies, heated mirrors, heated seats bad Willing to Buy by private party 3 10-29-2011 12:57 PM
HEATED SEATS ANYONE?? 3dr5speedblk DIY / Maintenance / Service 29 12-02-2010 09:28 AM
Heated Seats DevilGirl General Yaris / Vitz Discussion 1 11-25-2009 10:20 AM
Heated Front Seats How-To Post TC-LIFTBACK DIY / Maintenance / Service 15 12-05-2006 10:43 AM
Powered by vBulletin® Version 3.8.0
Copyright ©2000 - 2019, Jelsoft Enterprises Ltd.
