Old 06-17-2017, 05:11 PM   #1
JustDidIt
JustDidIt's Avatar
Drives: '08G2T Prius
Aftermarket parts for SALE!! DC Sports Header, Injectors, MAF adapter, Greddy EMU....
  1. 1ZZ 260cc (1NZ are 200cc) Denso Flow Matched Fuel Injector Set for Toyota-Pontiac part # 23250-22080 (4)
    Never Installed.
    $50
  2. China KnockOff 2" 50mm straight Flange Pipe+ ADJUSTABLE SSQV SQV Blow Off Valve BOV II 2 BLACK
    $35
  3. DC Sports header AND flange retrofit
    $200
  4. Toyota MAF adapter/flange that is ready to be welded to 2" piping
    $50
  5. Custom short-ram Air Intake with 2" MAF adapter Kit.
    $100
  6. 2nd hand Greddy E-Manage Ultimate
    $350
    Most other stuff is really strictly for the Gen2 NHW20 Prius but if you are interested the for sale thread is over at PriusChat.com
JustDidIt is offline   Reply With Quote
Old 07-01-2017, 03:18 PM   #2
JustDidIt
JustDidIt's Avatar
Bump!
Still available!
    Never Installed.
    $50
    $35
    $200
    $50
    $100
    $350
Old 07-28-2017, 08:58 PM   #3
chaditotx
Drives: 2007 3dr hb 5sp
What's thw flange retro fit for on the header?
chaditotx is offline   Reply With Quote
Old 07-28-2017, 10:15 PM   #4
JustDidIt
JustDidIt's Avatar
It won't be needed for most cars, I had it made so it would work on my 1NZFXE Prius.
Old 07-29-2017, 02:09 PM   #5
SirDigby
Drives: 2007 yaris 3 door
is that the weirdo thing on the o2 sensor?
Old 07-29-2017, 04:24 PM   #6
JustDidIt
JustDidIt's Avatar
Heat shield for O2 sensor is above mid pipe flange adapter
Old 08-06-2017, 02:47 AM   #7
HOSHPOSH
TEQ
Drives: 2009 Yaris S TRD Package
Is the head e.o. conpliant for CA?
If so pm me, interested...
HOSHPOSH is offline   Reply With Quote
Old 08-06-2017, 11:59 AM   #8
JustDidIt
JustDidIt's Avatar
What? Not sure I understand what you meant...
Old 08-06-2017, 01:17 PM   #9
deng
Radical Dreamer
deng's Avatar
Drives: off of T9
No header for the Yaris is CARB exempt.
If you lack driver skill, add horsepower.
deng is offline   Reply With Quote
Old 08-06-2017, 03:59 PM   #10
JustDidIt
JustDidIt's Avatar
I ran this header in California and had no issues passing vehicle inspections if that's what you mean...
Old 02-01-2018, 03:38 AM   #11
daddz07
Drives: Yaris 2008
Send a message via Yahoo to daddz07
    Never Installed.
    $50
    $35
    $200
    $50
    $100
    $350
still available? Headers?
daddz07 is offline   Reply With Quote
Old 02-01-2018, 11:01 AM   #12
JustDidIt
JustDidIt's Avatar
Headers - no. Everything else - Yup!
    Never Installed.
    $50
    $35
  3. Toyota MAF adapter/flange that is ready to be welded to 2" piping
    $50
  4. 2nd hand Greddy E-Manage Ultimate
    $350
  5. 1NZ Quantum Technologies GT12 turbo kit
    $1000
Old 02-16-2018, 07:49 AM   #13
JustDidIt
JustDidIt's Avatar
Bump!
    Never Installed.
    $50
    $35
    $50
    $350
    $1000
Old 05-08-2018, 05:56 PM   #14
JustDidIt
JustDidIt's Avatar
Bump!
$350
$1000
Included with this kit:
* Garrett Turbo - GT1241 from hydrogen turbo kit
* Fabricated exhaust manifold - Hydrogen Turbo Kit
* Down pipe flange to be welded to stock exhaust
* Fabricated intake and intercooler plumbing - 2 inch and 1.75 inch mandrel bent - Hydrogen Turbo Kit
* One heat range colder Iridium spark plugs - 2 step colder NGK 2667
* Intercooler - Hydrogen Turbo Kit came with a Spearco
* 2" Airflow MAF adapter needs to be welded to intake piping
* eBay HKS blow-off valve (2" 50mm straight Flange Pipe adjustable SSQV SQV BOV BLACK
* 1ZZ-FE injectors for 30% more fuel flow (Denso Flow Matched Fuel Injector Set for Toyota-Pontiac 1.8 23250-22080 (4))
* 10AN Universal Steel Oil Pan Return Drain Plug Adapter Bung Fitting Weldable
* 4pc -10 AN Fitting Straight Black Swivel
* (4) 2" to 2" Black 45 Degree Elbow Silicone Hose Coupler
* 90 Degree Swivel 4AN Male to Female Fitting Adapter
* 10AN 45 Degree black Swivel Fuel Oil Air Gas Hose End Fitting Adapter
* 4AN Male Flare To 1/8" NPT Pipe Thread Straight Black Aluminum
* (2) Black AN10 Nylon And Stainless Steel Braided Fuel Oil Gas Line Hose -10AN
* (2) AN10 45 Degree Swivel Oil Fuel Line Hose End Fitting
* 10AN 90 degreeTurbo Oil Pan / Oil Return Drain Plug Adapter Bung Fitting no Weld
* Black 8AN Female to 10AN Male Flare Fitting Expander Adapter 8AN to 10AN
* 1/8 NPT Hex Head Pipe Plug Fitting Black
* 4AN to 1/8'' NPT Straight Adapter Pipe Fuel Oil Air Fitting Black Color
* 1/8" BSPT Oil Pressure Sensor Fitting
* Universal Polished 2'' 51mm Aluminum Intercooler Pipe Kit
* (2) 1.75-2" 3-PLY universal reducer turbo/intake piping connector black silcone coupler
* (3) 1.5" TO 2" 3-PLY universal straight turbo/intake piping connector black silcone coupler
* (1) 1.75"-2" 90 degree reducer 4-PLY straight turbo/intake piping connector black silcone coupler
* (4) 2" 3-PLY straight turbo/intake piping connector red silcone coupler
* 2" 52mm PSI Universal Digital Boost Vacuum Gauge Meter Car LED Red & Blue
* 2" 52mm Universal Digital LED Car Oil Pressure Meter Gauge Red & Blue
* Turbo Water Feed & Return Line Kit Garrett GT12 GT1241
* Turbo Oil Feed & Return Flange Garrett GT12 GT1241 4AN Feed / 8AN Return
* Universal 36" steel oil feed linke kit 1/8 NPT
Old 05-08-2018, 11:00 PM   #15
Runethecursed
is that emanage the 1nz specific one?
Runethecursed is offline   Reply With Quote
Old 05-08-2018, 11:02 PM   #16
JustDidIt
JustDidIt's Avatar
Universal - wasn’t aware of one made specifically for the 1NZ. I think they make boomslang plug and play adapter for the EMU and the 1NZ but the EMU alone isn’t specific to the 1NZ.
Old 05-08-2018, 11:06 PM   #17
Runethecursed
My casual google skills leads me to believe its a boomslang harness for the NZ. I might have to hit this up soon. It's /Piggyback/ style allows it for STS class racing
Old 05-08-2018, 11:07 PM   #18
JustDidIt
JustDidIt's Avatar
Sounds good. I’m in no rush to sell, may end up using this for my 2GRFE build.
MRW makes a boomslang for it and the 2GRFE to work with the EMU.
FYI: Aftermarket parts from Japan (NCP131) yarisugi Third Gen Yaris General Discussion 26 01-30-2016 06:43 AM
FS: Aftermarket parts (need to pass SMOG) biggestsack Items for Sale by private party 37 06-09-2013 11:31 PM
your used or unused aftermarket parts savister Willing to Buy by private party 6 04-29-2010 04:16 PM
Problem with Yaris aftermarket parts manufacturers GMKing Performance Modifications 11 09-14-2009 12:08 PM
