08-17-2017, 07:19 PM | #1 |
Drives: 2009 Yaris 5 door Join Date: May 2015
That was a fun ride home
Started surging, then dropped out of 4th into 3rd, and slammed back up into 4th. Over and over. Off to AAMCO for a new solenoid.
https://www.youtube.com/watch?v=nSz16ngdsG0 |
08-19-2017, 11:15 AM | #2 |
Just got a call from AAMCO, and they told me the following. The speed sensor is fine, and is supplying the correct input to the speedometer. From there it sends a signal to the ECM, which controls the shift solenoids. It's losing voltage from the cluster to the ECM, and the car thinks I'm doing 35 mph when the speedometer reads 70. They said the transmission is perfectly fine otherwise.
Has anyone had this happen?! This thing is my daily and I have a 150+ mile daily commute. Just buy another cluster and have a dealer reflash my keys?? |
10-26-2017, 10:39 PM | #3 | |
Sir Rustalot
Drives: Toyota Yaris silver 2000 reg Join Date: Sep 2017
manual or auto the age old question?
If it wasnt for my modesty ,i would be perfect ! |
10-27-2017, 01:12 AM | #4 |
Drives: '15 Yaris SE 5MT Join Date: Jun 2014
Like clutches, etc. don't fail before 218K miles...
03-01-2019, 12:06 AM | #5 |
It was a bad ground bolt. The factory location was corroded almost all the way through, maybe 1/16" left. I welded in a patch panel and it fixed it right up. So it wasn't a communication between body computers, sensors, or anything else dealerships and transmission shops recommended.
03-01-2019, 08:11 AM | #6 |
2ZR swap. DO IT! Ask how!
Wow, a year and a half with that problem? Ouch! =D
Thread Tools | |
Display Modes | |
