Old 12-21-2010, 07:49 PM   #1
YAR1S
YAR1S's Avatar
Bi-Xenon High Beams Not working
My high beams on my bi-xenon hid kits stopped working.
I dont hear the "thud" of them tilting anymore?
any tips to fix???
the regular beams still work, and the indicator light on the dash comes on, the fogs turn off and normal lights stay on, but no high beam!
-Jen <3
Old 12-21-2010, 10:09 PM   #2
With the kit that you bought, how is the high beam solenoid (the device that flips the shield) wired? Does the ballast control it, or is it wired directly to the high beam feed?
Old 12-22-2010, 09:03 AM   #3
likely need new HID bulbs...
Old 12-22-2010, 10:27 AM   #4
You have much more experience with the HID kits than I do, but my understanding is that many of the HIDs with the solenoid shield have issues with the solenoids burning out due to over driving them. There are three wire solenoids that have two coils - A high current one for flipping the shield and a low current one to hold it once it is flipped. The high current one isn't intended to be left on for holding.
Old 12-22-2010, 11:57 AM   #5
Doesn't that kind of bulb only make one brightness? --- If lo/hi is controlled by a solenoid, and low beams light up, then the bulb is good right?
Old 12-22-2010, 12:17 PM   #6
bulb sounds like itd be a "flexible" bulb where it tilts for the high beam
ive seen them stop working every now and then...its just easier to get a new bulb/bulbs if you want high beams...
depending on when/where you got it, it SHOULD be warrantied
Old 12-22-2010, 11:14 PM   #7
YAR1S
YAR1S's Avatar
Well, as far as a waranty, Im not sure, can you chime in Caliyaris? I got them from you ....
The low beams are working fine, so why would I need new bulbs? shouldnt it just be a wiring issue? if anything I would have thought a new harness would be the fix. I really dont want to have to change it all out though! :(
-Jen <3
Old 12-22-2010, 11:36 PM   #8
Mine don't have "flexible bulbs", just the one with a solenoid-controlled shield.
Old 12-23-2010, 07:18 AM   #9
Do your kits have the two wire or three wire solenoids?
Old 12-23-2010, 08:01 AM   #10
jamal1984
The Beautification of Car
Drives: Toyota Yaris S
Send a message via MSN to jamal1984
8 out of 10 problems on my car about hid highbeam is the relay Harness i went throught with 3 relay harness in 1 year, and them relay harness cost you around 30?
jamal1984 is offline   Reply With Quote
Old 12-23-2010, 09:57 AM   #11
@ CTScott - 2 wires, pretty sure.
@ OP: if you are within warranty you get new parts, but we need to clarify which parts you need.
Old 12-23-2010, 12:06 PM   #12
OK - If it's this kit from your store, then it looks like the solenoid is controlled by the ballast. So, it could either be the solenoid or the driver that is bad, but I would think that the solenoid is the more likely culprit.
Old 12-23-2010, 12:30 PM   #13
that looks like an h11 kit...
i don't have any pics of the kits i sell right now, but i can take a pic of the wiring harness, etc later
the ones i use have 2 wire solenoid (iirc) that moves the bulb
Old 12-23-2010, 12:38 PM   #14
^ alright, I'll also post a pic of the H4 kits I have.
Old 12-24-2010, 02:21 PM   #15
YAR1S
YAR1S's Avatar
the box I got was a dark black, I only got the lights less than a year ago maybe?>
-Jen <3
Problem with low beams and High Beams thebarbrr DIY / Maintenance / Service 7 09-22-2010 08:43 AM
Yaris sedan low and high beam jorizk DIY / Maintenance / Service 10 03-02-2010 09:49 AM
High Beam Issues urbanmindz In Car Entertainment + Electronics (audio / video / alarm) 0 03-19-2009 09:22 PM
Package received from Taiwan! GabL Cosmetic Modifications (Exterior/Interior) 74 09-25-2007 09:37 AM
DIY - HID Retrofit Violin DIY / Maintenance / Service 57 06-11-2007 06:17 PM
