Old 08-20-2018, 09:13 AM   #1
bronsin
bronsin's Avatar
A trick to changing your battery
If you remove your battery the computer needs to relearn everything I learned when the battery was hooked up. I change the battery in my wife’s car at five years ago she go to work and it wouldn’t start. The computer had learned enough yet.
So there is a plug you can get that plugs into the OBD two terminal and there’s two alligator clips to hook a battery to. I use my tractor battery. This way the computer Always sees 12 V when the old battery is removed.Always sees 12 V when the old battery is removed.
https://www.amazon.com/Outzone-Memor.../dp/B075WV4P7K
Old 08-24-2018, 06:02 PM   #2
Tedtalker
Drives: 2007 Yaris Sedan
Thanks for the info.
Yaris - It's A Car !
Tedtalker is offline   Reply With Quote
Old 08-24-2018, 11:11 PM   #3
kevinj93
kevinj93's Avatar
Drives: 2013 NCP130
How long did it take to change the battery?
I don't know how long the ECU memory holds up for once the battery is disconnected, but most battery installers here use these devices to avoid having to put the security code into the car radio.
Old 08-25-2018, 07:28 AM   #4
ex-x-fire
Just be careful, the battery cables will still be live even though the battery is unhooked. I wrap the positive in a rag.
Old 08-25-2018, 05:46 PM   #5
kevinj93
kevinj93's Avatar
Drives: 2013 NCP130
Good point. I hadn't thought about that.
Old 08-27-2018, 01:21 AM   #6
komichal
I do not know how long it takes the computer to re-learn everything.
The only impact I noticed when changing the battery was that I lost all the saved radio stations. And the clock re-set too.
Other than that - no difference.
This tip you mentioned is useful for sure and I have heard that some cars even "forget" their security settings and you cannot get inside even with the original key after a battery is replaced. Which is crazy. Luckily for us, Yaris is not this car.
Personally I disconnect my battery on purpose, whenever I work on the car. Just for security reasons. After all, it is an excellent opportunity for me to finally set the dashboard clock to exact time (as the dashboard clock in my Yaris slows down approx 1 minute per month).
Old 08-27-2018, 03:20 PM   #7
bronsin
bronsin's Avatar
Maybe an hour from removal, travel to and from the store, and the actual installation.
Old 12-23-2018, 10:30 PM   #8
mel0526
Drives: Yaris 2008
I changed my battery yesterday and my car won't start anymore. How do I get the security code? And do I enter it in the radio?
Thanks
Mel
mel0526 is offline   Reply With Quote
Old 12-24-2018, 07:58 AM   #9
Thanks
Mel
The talk of security code in this case refers to a theft deterrent measure of the radio itself. Some radios, when disconnected from power, will require a security code entered into it in order for it to function again. Has nothing to do with a car that will not start.
We Have the Beats! ern-diz Photo-Video-Media Gallery 41 05-15-2018 05:58 AM
Battery keeps going dead Outdoorsman In Car Entertainment + Electronics (audio / video / alarm) 6 09-09-2013 04:43 PM
Ohm's Law and Setting Amp Gain _S7V7N_ In Car Entertainment + Electronics (audio / video / alarm) 24 03-13-2012 09:34 PM
