Old 11-19-2016, 04:25 PM   #1
yaris9876
Drives: yaris hatch 07 640K original m
clutch replace
If you do a clutch replacement...you have to remove both axles from both the left and right
front assemblies..yes??
yaris9876 is offline   Reply With Quote
Old 11-20-2016, 05:57 PM   #2
CoryM
Drives: 2009 5-door, 5-speed
Technically you don't have to, but it is best to remove them so they aren't interfering.
Old 11-20-2016, 08:57 PM   #3
Remove from transmission
Old 11-21-2016, 10:46 PM   #4
SirDigby
Drives: 2007 yaris 3 door
I only have one axle on the left, and one on the right
Old 11-30-2016, 12:37 PM   #5
yaris9876
have any of you been inside a manual trans for the yaris??? like a rebuild of the gears etc..?
Old 11-30-2016, 09:03 PM   #6
SirDigby
it's pretty much the same as any 5 speed transaxle make in the last 30 years.
what's your question? is it, "can you rebuild gears?" cause the answer is no. damaged gears need to be replaced.
Getting Rid of the infamous Clutch "Shudder" tmontague DIY / Maintenance / Service 14 07-08-2023 01:56 PM
Clutch Maintenance fnkngrv DIY / Maintenance / Service 12 03-03-2017 10:42 AM
Aftermarket Clutch Q's tmontague Performance Modifications 5 03-05-2016 04:33 PM
Unique Smell from Air Going Through AC Blower EddieCabael DIY / Maintenance / Service 30 01-19-2015 09:08 PM
need help on my 2008 yaris compress clutch susucosp DIY / Maintenance / Service 0 05-15-2014 03:48 PM
