10-22-2018, 09:48 PM | #1 |
Drives: 2008 Sedan Join Date: Jul 2017
Oxygen sensor issues
My dad has a 08 Yaris sedan. He recently had the exhaust manifold replaced. The first oxygen sensor kept setting off the check engine light immediately. He had it replaced with an ultra-power brand one from rockauto. Immediately after it started feeling like it was cutting out almost, but the check engine light didn't come on. They thought it might be the secondary sensor being older that it might be slower. That one was replaced with an ultra- power brand one. It cuts out somewhat less but the check engine light still hasn't come on. The car never acted like this before, it had an exhaust leak, but no check engine light and plenty of power for a car like it. Now it's kind of a dog under load and cuts out. Any suggestions?
10-23-2018, 02:16 AM | #2 |
Drives: 2015 Yaris L Join Date: Jun 2017
Depending how long that has been going on, it could just be a ecu re-learning process. After cleaning my MAF sensor and throttle body with battery unhooked, my engine ran rough for a bit before it settled down.
After you changed your O2 sensors did you remove the ground off of the battery to clear the computer? |
10-23-2018, 09:55 AM | #3 |
Yes, the battery ground was removed for about 15 minutes. It has been over a month.
10-23-2018, 07:00 PM | #4 |
Drives: Corolla 1.8 Join Date: Oct 2010
Do you change the exhaust manifold gasket?
Thread Tools | |
Display Modes | |
Similar Threads | ||||
Fault code P2196 Oxygen sensor? | Saphe | DIY / Maintenance / Service | 9 | 12-16-2021 08:07 AM |
Oxygen sensor | Spellino | DIY / Maintenance / Service | 6 | 11-08-2017 09:56 AM |
1999 yaris oxygen sensors | jblomster | DIY / Maintenance / Service | 6 | 08-16-2015 07:36 AM |
Signal wire on Oxygen sensor??? | d.one | DIY / Maintenance / Service | 8 | 04-25-2013 12:28 PM |
need quick help to find oxygen sensor | mariann | DIY / Maintenance / Service | 11 | 10-02-2012 01:09 PM |
