Old 12-04-2017, 08:07 AM   #1
rabbito
rabbito's Avatar
Drives: 2012 Toyota Yaris Sedan (Vios)
N/A build completed....
okay so this is it...i really wanted to fully mod NA and see how far it goes(without internal polish etc)..it doesnt matter how slow it is, i wanted to see the maximum potential of 1nz..yes i would have made 60whp+ on honda engine with this set up but yeah....
it was a fu*ken b*tch to get and connect brake booster and evp vacuum hoses...
- k&n pod intake to tb..spacer and intake manifold..hoping this gives out at least 10whp...that intake pod sound is really annoying lol..i am going to compare from my last dyno result...
- crank and pcv delete (no law)
- lightweight pulley...rpm speed increased with this set up..around 500rpm faster..
- 320cc injector E85 with piggyback ecu control unit & 272 9.5 cams (without valve/springs) set to 7,300rpm...this was probably the biggest hp i gained....this set up gave me about 15~20whp
- grounding wire with battery safe unit
- header....probably get 2 or 3 hp out of this setup...haha...
my afr reading lean..cars slow af right now..its like going than suddenly cars going lean...lol....i will update tomorrow with retune/dyno
Sent from my SM-J730GM using Tapatalk
Brain: ATD E85 Timing Advance ECU
Engine: 1JZ Injectors, Header, Center Pipe, K&N Drop In, E85 Injector Converter
Suspension: Hankook Tires, Performance OEM replacement Shocks & Springs F: 1.5 B: 1.4, Mu Spec brake pads, Front tower & Rear sway bars, Rays nut & lock
Electric: Volt Stablizer & Multi gauge obd2
Cosmetic: Toyota red emblem
rabbito is offline   Reply With Quote
Old 12-04-2017, 10:49 AM   #2
JustDidIt
JustDidIt's Avatar
Drives: '08G2T Prius
Wonder if you would have more luck with your tune by ditching the piggyback and using your oem ECU and have R9KTuning tweak it? He can modify A/F, timing, Set rev limiter..etc.. hes had luck on other 1NZ Ecus...
JustDidIt is offline   Reply With Quote
Old 12-04-2017, 12:03 PM   #3
tmontague
tmontague's Avatar
I'm curious if the factory ecu is trying to compensate for the tune that the piggyback is trying to run through it
I like to drive a slow car fast...
Old 12-04-2017, 12:04 PM   #4
rabbito
rabbito's Avatar
asia have much better aftermarket softwares....piggybacks cannot do full control as standalone but it does the job :)
well tomorrow it is.....
Old 12-05-2017, 02:50 AM   #5
xnamerxx
0-60 in slow
xnamerxx's Avatar
Drives: light blue liftback
What intake manifold is that?
2014 BSpec Divisional Champion
Old 12-05-2017, 07:19 AM   #6
rabbito
rabbito's Avatar
so it failed......a friend of mine with exact same set up with manual had 131whp...
we rechecked the engine regardig spark plugs, coil, engine compression..no leaks and new injectors...
intake manifold made over 40% air increase...oh shit right? no....this is fail for automatic transmission....they cannot handle 40% air increase like manual transmission does, even though we make extra injection to mix fuel the afr ratio is way too high(about 15 afr)..
so at the end of the day.....no intake and intake manifold for automatic transmission...lol
it can be done if i have a supercharger...but for just pure n/a...no...
its custom manifold by brd...
Old 12-05-2017, 08:50 AM   #7
fredovvti
Drives: Yaris 07 HB
Dude, change to manual. End of problems!!
fredovvti is offline   Reply With Quote
Old 12-05-2017, 09:48 PM   #8
malibuguy
Obsessed with 1.5L
Drives: '10 PW Yaris Sedan
Those are awfully short runners Im not suprised it didnt make any power.
-Greg...the Exhaust Freak.
-'10 PW sedan 106whp/110wtq, full exhaust, suspension goodies
-'82 Malibu, 1uzfe swap
-97 Tercel coupe, 1nzfe swap coming soon
-'84 Bonneville, 311, 200r4, 4.11 8.5 w/ spool
Old 12-07-2017, 01:54 PM   #9
xnamerxx
0-60 in slow
xnamerxx's Avatar
I guess I don't follow what happened?
Your power numbers are still awfully low for whats been done to the car, I think the piggyback isn't helping all that much. With the stock TB and intake I'm well above your power numbers. With the 272 cams your peak power should be right around 8k give or take and I would expect even higher given the short runners of that intake.
I know what I had my air filter setup like yours I was seeing 200 or so degree intake temps
Old 12-07-2017, 06:06 PM   #10
malibuguy
Obsessed with 1.5L
I currently run a short intake sort of like that and my temps never get that high. Even in the summer sitting in traffic. When i am moving its always near ambient
Old 02-02-2018, 09:46 AM   #11
firebird1999us
firebird1999us's Avatar
Drives: 2003 Mach 1
What header is that? Did you replace the factory mid pipe as well?
firebird1999us is offline   Reply With Quote
Budget 1nzfe build (n/a) nuclear90 Performance Modifications 5 12-10-2014 06:17 PM
1NZ-FE All Motor Build burned Performance Modifications 19 10-24-2014 10:56 AM
N/A Build !! Gabwone Tracking, Racing, Auto-X Forum 18 10-23-2014 05:12 PM
Warranty Information for US Yaris Owners AdeJong 03 General Yaris / Vitz Discussion 4 09-19-2009 10:14 PM
Copyright ©2000 - 2019, Jelsoft Enterprises Ltd.
