Old 11-23-2017, 07:10 PM   #19
Ab9000
Drives: 2008 Yaris hatchback
im having the same issue and its getting scary driving on the freeway. I went to a Firestone and they checked shocks/struts which were okay. They put on new tires and did an alignment. The tires are Champion Fuel Fighter BL 185/60r15. Are these okay tires?
With that wandering/floating feeling is there any chance the car can just flip over? It certainly feels like it when the freeway veers right.
Ab9000 is offline   Reply With Quote
Old 12-05-2017, 02:10 AM   #20
bairjo
If your car does not have one already, get a rear sway bar installed first, then consider new tires if still needed..... they are easy to install. just do a diy rear sway bar search on here for more info.
Old 12-05-2017, 09:50 PM   #21
IllusionX
Drives: 07 Yaris Sedan Aero
I don't think I've ever mentioned before. Be careful when just adding a rear sway bar to a stock car. The car will oversteer more in corners.
Old 12-06-2017, 12:37 AM   #22
bairjo
[quote=IllusionX;806759]I don't think I've ever mentioned before. Be careful when just adding a rear sway bar to a stock car. The car will oversteer more in corners.
Be careful at first but don't worry about it....i added one to my Yaris and on the flip side i would probably be concerned about how it handles if someone were to remove the sway bar without telling me..
Old 03-01-2018, 09:44 PM   #23
David C
Drives: White '07 3dr LB
Just add a few bags of sand in the spare wheel well. With an extra 80-100lbs or so on the rear axle you'll be just fine driving up to 80mph. With 150lbs on the hitch and 100lbs in the rear I got up to 100mph before the car felt a little float with a (driver) single occupancy.
steering wheel slight vibration high speed??? marcus Wheels, Tires and Suspension Forum sponsored by The Tire Rack 32 10-01-2012 06:36 PM
HIGH SPEED YARIS CRASH.... ROCKLAND TOYOTA Photo-Video-Media Gallery 25 03-10-2012 09:59 AM
Yaris sedan low and high beam jorizk DIY / Maintenance / Service 10 03-02-2010 10:49 AM
Have I mentioned how much I hate Speed sensors? staticorex General Yaris / Vitz Discussion 14 05-28-2009 04:04 PM
Six speed Snyprwlf47 Performance Modifications 16 11-24-2008 10:04 PM
Powered by vBulletin® Version 3.8.0
Copyright ©2000 - 2018, Jelsoft Enterprises Ltd.
