Old 08-18-2010, 03:17 PM   #1
Stiv
Drives: Yaris TS 1,8L
aFe intake broke
Hi guys,
I just took a look under the hood and saw that the little peace that is holding the intake sheild broke off. Well, almost. It's still holding everything in place, but it's just the matter of time before it snaps off. It's clear that the engine movement is the cause. I'll post some pictures as soon as I can. In the meen time, Garm, if you're reading this, do you have any ideas how to fix this?
Please guys, help me, I'm far away from home on holiday. God knows what I will do if this thing starts jumping inside engine bay.
Thanx
Stiv is offline   Reply With Quote
Old 08-18-2010, 03:33 PM   #2
hatchbackkid82
Drives: .
Same thing happened to mine as well, just bought a replacement heat shield
Old 08-18-2010, 03:53 PM   #3
Stiv
How much did it cost? And how can you be sure it won't happen again?
Old 08-18-2010, 05:02 PM   #4
Stiv
Here are some pics
1. Broken
2. Misaligned
What's up with this?
Old 08-18-2010, 10:05 PM   #5
Liu997
Drives: 2008 Red Yaris LB
Use some epoxy, always works
Liu997 is offline   Reply With Quote
Old 08-18-2010, 11:32 PM   #6
YarisSedan
YarisSedan's Avatar
Drives: 08 Yaris Sedan
Send a message via AIM to YarisSedan
Same thing happend to me i just removed the broken piece. What happens is our cars have no front engine mount so there is excessive engine movement. Depending on how you drive it will keep breaking off because one part is attached to the engine and moves with it while the other part is stationary. So there is a constant pressure and tugging against it as the engine moves back and forth.
Old 08-19-2010, 04:06 AM   #7
Stiv
Well, it's TS and it's roaring down the street. How would you drive it? :)
I could remove that broken peace, drill a hole or two and attach some strong rubber as a replacement. It should hold the sheild in place without breaking
Old 08-19-2010, 10:58 AM   #8
hatchbackkid82
Drives: .
I got it for like $40
Old 08-19-2010, 12:22 PM   #9
If you were here, it would be an easy warranty issue. I've contacted AFE about how they might offer to handle it. I think they should at least replace the broken airbox.
Old 08-19-2010, 01:14 PM   #10
Stiv
Ok, thank you Garm. Keep me posted
AEM cold air intake vs Afe intake... djgab101 Performance Modifications 69 04-28-2013 02:03 PM
AFE Intake and NST 10% UD Pulley Gray hatchbackkid82 Items for Sale by private party 12 04-17-2010 09:16 PM
aFE intake for sale $135 kngrsll Items for Sale by private party 5 01-19-2010 04:53 PM
Garm's AFE intake vs. TRD high flow air filter???? computerlove87 Performance Modifications 28 07-22-2009 05:05 PM
