Old 01-25-2015, 05:21 PM   #1
Surubi
Drives: Yaris Verso/ Fun Cargo
Shifting Problems Automatic Transmission
Hello this is my first time posting here. I was hoping to get some help with my car. I drive an automatic 2000 Toyota Fun Cargo(Yaris Verso). Recently while driving in D(drive) the 2nd gear light came on along the D (drive) light. Now even when the car is in Park the 2nd gear light remains illuminated. The main problem is, the car will now only shift between first and second gear no matter the gear I put it in. Does anyone know whats going on?
Thank you in advance for any help!
Surubi is offline   Reply With Quote
Old 01-25-2015, 05:48 PM   #2
Check the connector on the assembly which the shift cable pushes. That switch assembly feeds the ECM the info on which gear is selected. If the switch assembly is bad or there is corrosion on the connector it may be telling the ECM that two things are selected at the same time.
Old 02-03-2015, 12:05 PM   #3
Surubi
Just to update. It was a bad SLT solenoid.
Old 03-14-2016, 01:52 PM   #4
MyzticZ3r0
Drives: 2007 Toyota Yaris Hatchback
Curious, how much did it cost you to replace? Did you go to a garage or DIY?
MyzticZ3r0 is offline   Reply With Quote
How frequently does the automatic transmission fluid need to be changed? Hamster DIY / Maintenance / Service 40 12-15-2018 09:07 PM
Automatic Transmission to Manual Zarkos Performance Modifications 3 05-22-2014 12:24 PM
Problem help MickZEL DIY / Maintenance / Service 38 08-01-2011 02:52 PM
Automatic or manual transmission bentjazz Fuel Economy Forum 31 03-03-2011 01:52 AM
Want opinions automatic vs. manual transmission anik New YARIS Purchase Forum 84 07-10-2007 04:25 PM
