03-26-2019, 09:02 AM | #127 |
Drives: 2008 yaris 5dr hatch Join Date: Apr 2016
No secret but they were used and only set but prob can find new. Ill find thenlink and post if I can
Sent from my moto e5 play using Tapatalk |
03-26-2019, 09:09 AM | #128 |
Daystar KC09103BK Comfort Ride 1.5-Inch Front Coil Spring Spacer Kit - 2 Piece
[https://images-na] They aren't perfect but I paid 20 CAD shipped to the house so if they didnt work I wasnt out much. Sent from my moto e5 play using Tapatalk |
03-27-2019, 08:54 AM | #129 |
2ZR swap. DO IT! Ask how!
Your linky no worky. =D
03-27-2019, 08:58 AM | #130 |
Sorry, was on my phone and the copy paste must have buggered.
These: https://www.amazon.com/Daystar-Level...y&sr=8-1-fkmr0 I only paid 20 shipped CAD for the set I got, were supposedly used but were NIB when they arrived. had never been installed. |
03-27-2019, 01:13 PM | #131 |
Thanks to Myfirsttoyota for the site I have the tire comparison below. the Grabber ATX are listed as 26.9" but .1 of an " is not enough to matter. I need to measure my clearance and may need to mod my lift some more. I did math but I think I got the wrong measurement on the small tire the first time maybe.
03-27-2019, 01:17 PM | #132 |
3 Yaris and counting..
I like the beefy sidewall on the 14" rim!
Gonna feel like you're driving on beach balls!! Lol
03-27-2019, 01:27 PM | #133 | |
Doing the maths as the GT guys say. I am giving the car 1.5" of lift. 26.9" Grabber - 23.5" Altimax = 3.4" Diameter / 2 = 1.7" needed clearances. I will need to maybe install a spring stiffener to the front or back and cut the bumpers a bit. I am also willing to trim fender metal and add flares and offset with spacers for the width of the tire. I am going to do some measurements in the back wheel wells and arches now that the lift is in a settled from a few drives to work and see where I might get an issue or not. |
03-27-2019, 02:02 PM | #134 |
Drives: 06 2ZR Turbo Yaris RS Join Date: Aug 2017
03-27-2019, 02:24 PM | #135 |
Drives: 2008 Toyota Yaris 5dr Liftback Join Date: Jul 2012
You may be able to get away with the amount of lift you’re putting on. I’m running 185/65r15s on stock steelies, which are 24.5” diameter, and have no issues with rubbing.
When I bought the tires they were originally mounted on Kia Rio wheels which were the same width but had a +36 offset instead of the stock +45 and I got rubbing over bad bumps where the fender attaches to the bumper. It’ll mainly be the fun trial and error in finding out what works best I think! Excited to see those beefy grabbers on there though!
Hot Rhonda 2008 Toyota Yaris 5dr Liftback - Bayou Blue - Cosmo Racing Short Shifter - Kenwood Single DIN Aftermarket Headunit - Rockford Fosgate Punch 6.5” Speakers “the dents make her handle better.” |
03-27-2019, 02:32 PM | #136 | |
03-27-2019, 02:35 PM | #137 |
so my sport edition F12's are 14X6 38MM offset. you say 45MM is stock. I need to remember myself what that means for wheel in well position. Less puts wheel farther out bound, more puts it more inbound or is it the reverse?
Size: 14x6 Offset: 38mm Backspacing: 5.00" Bolt Pattern: 4-100 Rec. Tire Size: 175/65-14 Weight: 15.0 lbs. |
03-27-2019, 02:43 PM | #138 |
Yeah so the +38 will sit 13mm further away from the strut. Wheel width is another thing to take into consideration though. For example, the wheels I had for a Kia Rio were 5.5” wide and +36 offset. The tire shop was originally going to order me a 6” wide wheel with a +45 offset. With the extra 0.5” wheel width the offset difference wouldn’t have mattered.
This is a good website to get a visual of how offsets and widths will affect your wheel placement. https://www.willtheyfit.com
03-27-2019, 02:44 PM | #139 |
If you do go the route of the 27x8.5 grabbers maybe take a peek at what the minimum required wheel width is for that tire too, might factor into things.
03-27-2019, 02:45 PM | #140 |
Thanks. sorted that already 6 is the min and I was about to calculate some stuff but I'll check the link you posted first.
03-27-2019, 03:00 PM | #141 |
OK, from that site, I am good for suspension clearances. Outer wheel arch may rub but I won't need offset spacers from the looks of it. The protege wheels I have are 14X5.5 45MM offset. The wider tire, had to put closest Pmetric size as 27x8.5 screwed it up.
03-27-2019, 03:03 PM | #142 |
oh and here is the plan to stop the over compression of the strut top rubber mount. Those are the bump stops out of my CRV struts I rebuilt.
04-02-2019, 12:26 PM | #143 |
So I have yet to get the modded lifts in the front but I did measure my rear wheel wells and I have 2.25" before the front of the arch would get hit, which means no trimming near the door. I'll need to trim the back bumper a bit as I have just about 1.5" at the rear of the arch and the tires are 1.6" bigger. We'll see for sure but trimming the plastic bumper is not a deal breaker. I need to mock up a fake tire on the alloy rims to check the front once I get it lifted finally. I may get to it tonight or tomorrow depending on honey do's etc.
04-02-2019, 01:43 PM | #144 |
You could just go to a tire shop or an auto junker and see what a cheap used tire that size would cost. I imagine not much. Might be able to give you a better idea for trimming if you have some actual rubber that size.
Interested to see how those grabbers look on there! They’re going to be some beefy tires!
Similar Threads | ||||
NEWS: TOYOTA REVEALS ALL-NEW YARIS SEDAN AT 2006 LOS ANGELES AUTO SHOW | VitzBoy | General Yaris / Vitz Discussion | 7 | 09-20-2023 07:50 AM |
DIY Cruise Control FAQ (2006-2010 Yaris) | CTScott | DIY / Maintenance / Service | 467 | 10-18-2022 10:20 AM |
Natural Gas Yaris | MadMax | General Yaris / Vitz Discussion | 13 | 06-03-2017 06:10 AM |
Vacationed in Italy - Brought home a D4D diesel Yaris | CTScott | Photo-Video-Media Gallery | 19 | 07-26-2012 03:13 AM |
