Old 12-23-2008, 06:07 AM   #1
mikenacarato
SIPNDEW
mikenacarato's Avatar
Drives: 15 STI
need pinout of ignition switch
i was wondering if someone could tell me what the pinout of the ignition switch is. i have looked at the connector and see it has 6 wires running to it. what is each wire?
thanks!
mikenacarato is offline   Reply With Quote
Old 12-23-2008, 07:33 AM   #2
there's actually 7 wires? I looked into that, they connect in weird ways at each stage (ACC-ON-START)... look at the engine control PDF on www.etimago.com/yaris/repairmanual , page ES-249
Old 12-23-2008, 12:49 PM   #3
mikenacarato
SIPNDEW
Drives: 15 STI
i looked at my plug last night and spot # 3 and spot where #8 would be are empty. and 7 (black wires) have 2 wires running into that same hole. how can i tell what color is what in that diagram? lol
Old 12-23-2008, 03:29 PM   #4
The 09 pinout and colors are a bit different than the 07 and 08:
Yellow - Switched +12 VDC
Pink - Ignition
Green - Start
White - Accessory
Old 12-23-2008, 04:35 PM   #5
mikenacarato
SIPNDEW
Drives: 15 STI
thanks a ton!
Old 12-25-2008, 01:58 AM   #6
mikenacarato
SIPNDEW
Drives: 15 STI
is there a constant 12V here or do i tap into it elseware?
Old 12-25-2008, 03:55 AM   #7
IsLNdbOi
IsLNdbOi's Avatar
Someone really needs to upload the '09 service manual and other '09 related files here.
Old 12-25-2008, 10:17 AM   #8
Constant 12V is best gotten off of the fuse panel. Look at the red wire in this picture. Use a 1/4" female spade to connect to the top one of the two terminals.
Old 12-25-2008, 10:20 AM   #9
I will eventually. I subscribed to TIS for one day and grabbed all of the EWD's and about 90% of the rest of the 09 service manual. I just need to convert the EWD's from the .svgz format (readable to Adobe Illustrator) to PDF so all can open them and combine the 1000+ separate documents into smaller groups. I had to print each small section (2-3 pages each) to pdf from the TIS site.
DIY - Bypassing Tire Pressure Warning System (TPWS / TPMS) CTScott DIY / Maintenance / Service 217 08-11-2021 11:20 AM
DIY (08' USDM LB): Interior Light Color Change revnull DIY / Maintenance / Service 37 05-21-2016 12:59 PM
New Foglights with Wireless PILOT switch Rotorheader DIY / Maintenance / Service 3 08-11-2007 11:03 AM
replacement fog light switch? yrsdrgn Cosmetic Modifications (Exterior/Interior) 4 07-17-2007 04:11 PM
Ignition switch heats up kurokoma-kun General Yaris / Vitz Discussion 11 06-19-2007 02:53 PM
