Old 11-27-2015, 06:31 PM   #1
Eduardo_mty
2016 yaris sedan Cruise control
A friend bought a 2016 yaris sedan with automatic transmission.
I tell him, buy this oem parts
84632-08021 switch Speed control
84633-02020 Cruise control wire
90080-15079 screw w/washer
A few minutes ago, i installed but no work.
any help i will appreciated
Installation pics
uploadfromtaptalk1448666277224.jpghttp://<a href="http://[ATTACH]56198...1;/ATTACH]</a>
Eduardo_mty is offline   Reply With Quote
Old 11-27-2015, 07:15 PM   #2
Is it a US market Yaris or one from another market?
Old 11-27-2015, 07:16 PM   #3
Eduardo_mty
I live in México and VIN start with J
Old 11-27-2015, 07:33 PM   #4
OK. I thought that was the case.
Check for the presence of the connector D3 wires on the steering column connector. My 06-11 cruise control DIY shows the wire locations:
http://www.yarisworld.com/forums/showthread.php?t=33750
Old 11-27-2015, 07:52 PM   #5
Eduardo_mty
I found this
Old 11-27-2015, 07:55 PM   #6
Eduardo_mty
Old 11-27-2015, 08:00 PM   #7
OK. I see the blue and brown under the black, which should mean that it is wired for cruise. It also looks like it is wired for steering wheel audio controls. Do you see the cruise control indicators in the instrument cluster?
Old 11-27-2015, 08:03 PM   #8
Eduardo_mty
yes, the cruise control icon i can see it with flash light
Old 11-27-2015, 08:31 PM   #9
OK. I am not sure about differences in features for the Mexican market Yaris, but it sounds like everything necessary is in place.
The only other thing I can think of to check is the presence of the ECM connector pin.
Old 11-27-2015, 08:58 PM   #10
Eduardo_mty
thank you i will check tomorrow the ECM connector pin
Old 11-28-2015, 05:25 PM   #11
Eduardo_mty
I Checked, And i will need to buy ECM Comnector A21 Pin (82998-24240)
See pictures
Old 11-28-2015, 05:30 PM   #12
Eduardo_mty
CTScott do you think... Traction control will be install it, with "simple" /easy wiring and switch
See pictures
Old 11-28-2015, 09:36 PM   #13
The A21 pin being missing on the 2016 may mean that the Mexico market ECM does not support cruise control.
Traction control requires support of both the ECM and the ABS ECU, so it can not be added without changing those (and making sure that all of the supporting sensors are present).
Old 11-28-2015, 10:11 PM   #14
Eduardo_mty
Then if i do that you do in your 34 pages manual (section 3), i cant get Cruise control
Old 11-28-2015, 10:20 PM   #15
For the US Market Yaris that is true. I have not had experience with adding cruise to Mexico market Yaris, so we will find out with your work.
To test it, you can remove the rubber plug from that pin hole and stick a small piece of wire in from the back of the connector. If you measure the voltage on that wire with the ignition switch in the ON position you will see +12 V on that pin, if your car supports cruise control.
Old 11-28-2015, 10:23 PM   #16
Eduardo_mty
Thank you, i will do tomorrow
I will do....
1. Remove the negative wire from battery.
2. Remove the EMC Connector.
2.1 remove the waterproof Rubber plug
2. 2 install a wire
3. Reconnect the EMC connector
4. Reconnect negative wire to battery
5. Turn on the key
5.1 check wire voltage , if show 12v, it will work
This is the steps that i will do, its ok
Old 08-08-2017, 01:45 AM   #17
laobo
Drives: yaris sedan 2011
Hi friend. Did you have? Review your final
I will do....
2. 2 install a wire
5. Turn on the key
Can you show me. which is number pin of ECM ( ECU) for signal ccs ?
my car is 2014-2017 year
laobo is offline   Reply With Quote
I want to add cruise control on my 2009 yaris doorslammer DIY / Maintenance / Service 1 08-20-2015 12:28 PM
This is pretty frikken stupid - Yaris '07 LB auto cruise control firemachine69 DIY / Maintenance / Service 10 07-20-2010 08:09 AM
