Old 10-08-2019, 12:00 PM   #1
Toolaholic
Drives: Olive yaris,FRS, Dakota R/T
Alternator , thermostat water pump replacement
Here’s some pics of my Yaris under the knife
File Type: jpeg 235C781C-FDF4-4583-8DF6-556864A9D2F9.jpeg (170.8 KB, 79 views)
Toolaholic is offline   Reply With Quote
Old 10-08-2019, 12:03 PM   #2
Toolaholic
Last pic was Chapman driver (that fits) removing philps screw on a/c line support that when bolt underneath is removed it can moved down out of way
Old 10-08-2019, 12:24 PM   #3
Toolaholic
Armstrong 11-994 ratchet 3/8 to 1/4!adapter 14mm socket lower alternator bolt. Upper is 12mm
File Type: jpeg A5AD8D94-87AC-47B3-A778-E312086CF599.jpeg (224.1 KB, 80 views)
Old 10-08-2019, 12:31 PM   #4
Toolaholic
No room to pull lower alternator bolt out with ratchet so I used a 14mm locking flex head wrench angled to fit between alternator and a/c lines.
File Type: jpeg F1B0EA03-A001-4DC0-8D2A-0B53C0F0EC9E.jpeg (295.2 KB, 78 views)
Old 10-08-2019, 12:37 PM   #5
Toolaholic
Alternator out there’s your water pump
File Type: jpeg 7E5494F8-49C3-41B4-88FA-3728584F8B5C.jpeg (206.7 KB, 78 views)
Old 10-08-2019, 12:43 PM   #6
Toolaholic
And the thermostat housing
File Type: jpeg 23027EDD-2266-482C-8146-5D3C80F9E23D.jpeg (252.6 KB, 78 views)
Old 10-08-2019, 12:44 PM   #7
Toolaholic
Note the rusted nutin last photo .Whole stud came out with but seized to it. Bought a new stud and nut.
Old 10-08-2019, 01:12 PM   #8
Toolaholic
Use hose clamp pliers on lower road hose to thermo housing
File Type: jpeg 2B9F439C-BE59-4799-9EE5-0F1CB5B536C5.jpeg (223.9 KB, 74 views)
Old 10-08-2019, 01:21 PM   #9
Toolaholic
Hose off.
File Type: jpeg 7EC71E23-BE21-4481-BAC9-76E1F1E6B94B.jpeg (281.6 KB, 74 views)
Old 10-08-2019, 01:29 PM   #10
Toolaholic
I pulled thermostat out with a hook and pick
File Type: jpeg 7397EC16-86FF-48DB-AB13-369908AC37E7.jpeg (350.3 KB, 76 views)
Old 10-08-2019, 01:46 PM   #11
Toolaholic
New Thermostat and o ring. Out new stud in block with stubby 1/4 ratchet and 4mm socket. Cleaned housing with acetone/rag. Nuts are 10mm. Reassembled
File Type: jpeg 33F18C01-4C70-42FA-9BE2-353DB1FDCAC3.jpeg (277.5 KB, 75 views)
Old 10-08-2019, 02:08 PM   #12
Toolaholic
You should remove water pump pulleys bolts with belt on. I didn’t and put a 9 inch 1/4 extension to prevent pulley from turning. Scared back of pulley a bit. I used a new pulley so wasn’t concerned .
File Type: jpeg 481B18D1-0D2E-4C8A-B896-659DC12FE2C3.jpeg (147.2 KB, 74 views)
Old 10-08-2019, 02:15 PM   #13
Toolaholic
I removed 10mm water pump bolts/nuts with a 8 inch matco 1/4 drive ratchet . Lowest bolt is near the hump in pump at bottom. I accidentally removed timing cover bolt that is very close to water pump bolt.
File Type: jpeg 035B78B8-5D41-4291-BE8B-06503654DDB6.jpeg (198.9 KB, 75 views)
Old 10-08-2019, 03:06 PM   #14
Toolaholic
Removed pump. Far right is bottom bolt hole that’s hard to tighten and close to timing cover bolt . Note dried pink coolant
File Type: jpeg BE6126C8-FF35-4C36-8BE5-93D5FBF17D96.jpeg (399.7 KB, 72 views)
Old 10-08-2019, 03:08 PM   #15
Toolaholic
Tightening stud . Pump has 2 studs with 2 nuts and 3 bolts.
File Type: jpeg 027FEDAB-8B8A-47DB-B89E-B19324841183.jpeg (198.9 KB, 74 views)
Old 10-08-2019, 03:10 PM   #16
Toolaholic
Used permeated gasket remover and a razor blade at 90 degree angle. Ended up massaging goo gone oven cleaner on timing cover with m thumb 3 times . Throughly rinsing with water .
Old 10-08-2019, 03:16 PM   #17
Toolaholic
Install new gasket and pump . Tighten to 11nm or 97 inch lbs. I used 100 inch pounds. Shown is gearwrench torque wrench between pump and firewall. The back nut and bottom bolt had to be done leaning on engine cover torque wrench towards firewall.
File Type: jpeg A931AAE8-EA45-41AA-8056-41F831A33E80.jpeg (153.4 KB, 73 views)
Old 10-08-2019, 03:21 PM   #18
Toolaholic
Before torquing I tightened with little 3 inch tekton 1/4 ratchet. Then final torque with torque wrench
File Type: jpeg 16E6B010-A8BE-4352-9441-F3E618D31D2C.jpeg (259.2 KB, 69 views)
Water pump replacement guide? Mrb DIY / Maintenance / Service 5 02-05-2019 01:05 PM
Odd Fuel pump issue. Feeling at a loss. Marchalis DIY / Maintenance / Service 4 03-06-2018 08:55 PM
Location of Water Pump lululovesu DIY / Maintenance / Service 1 10-19-2014 08:05 AM
drive belt replacement and/or water pump replacement sociolog DIY / Maintenance / Service 9 02-10-2014 12:33 PM
Rear Shocks Replacement? Water Pump. babytic DIY / Maintenance / Service 7 06-15-2013 03:55 PM
