Old 03-16-2018, 10:30 PM   #1
Misfit
Drives: Yaris
How do I remove Ignition Lock Cylinder?
Hi Folks, 2012 Yaris Sedan:
I've got a bad ignition lock cylinder. After many failed attempts to get the key to turn to the ACC position, I finally got it to work. Now I need to remove the lock cylinder. I pushed the button with a bent nail. I pulled the lock out about a quarter inch.
I did a search on this forum and found that I also need to remove the "key sense" connection in order to remove the lock the rest of the way.
What is the "key sense" thing? Where is it? (my car does not have a chipped key) Thanks for your help.
Marv
Misfit is offline   Reply With Quote
Old 03-24-2018, 09:30 PM   #2
Misfit
Drives: Yaris
Well, since no one responded to my question. I'll give you an update. I took off the electrical connections that could in any way interfere with the key cylinder removal. The cylinder still would not come out more than a quarter inch.
Since the key was in the ignition, I drove the car to my mechanic. Who explained that the key cylinder was likely broken. He was able to break out the thing without damaging the ignition housing. He installed the cylinder I provided and all is well.
Marv
WTB: 08 Liftback Rear Lock Assembly - Not Lock Cylinder dbrear Willing to Buy by private party 2 10-06-2015 08:23 PM
Repaired ignition lock cylinder now no power for anything on steering wheel. blackace4 DIY / Maintenance / Service 10 09-16-2014 09:15 PM
Question replacing head gasket. Snyprwlf47 DIY / Maintenance / Service 3 07-13-2014 11:17 PM
