Old 01-11-2019, 08:57 AM   #1
siman338
Drives: Yaris mk3
Heater control unit replacement
Hi everybody!
I'm from Greece and i bought a mk3 Yaris 2013 imported from French.
A friend of me provided me an electronic (clima) heater control unit. My car has a manual heating control unit! Is there the possibility to replace my manual unit with the automatic one without any modification ? If not ... Can you inform me if l could fit the automatic unit and wchich part will i need in addition?
Thank you in advance!
siman338 is offline   Reply With Quote
Old 01-11-2019, 07:17 PM   #2
IllusionX
Drives: 07 Yaris Sedan Aero
Originally Posted by siman338 View Post
Hi everybody!
This was well documented in the forum. Use the search.
The auto climate control require quite a few modifications, and there are control modules that need to be added
Sent from my CLT-L04 using Tapatalk
Old 01-12-2019, 04:48 AM   #3
siman338
Drives: Yaris mk3
Thanks i will try to find it!
Old 01-12-2019, 10:31 AM   #4
Dodge Aries K
My Yaris is a "racecar"
Drives: 2007 Yaris hatchback
The knobs on your Yaris are all linked with cables to the various bits that move. To install the digital HVAC system you need the whole HVAC box under the dash that has the electric servos that move the blend door and mode door. That requires pulling out the whole dashboard.
-Karl the Uber/Lyft Driver
Dodge Aries K is offline   Reply With Quote
Old 01-12-2019, 11:02 AM   #5
It was documented on microimage. All gone.
Sent from my EML-L09 using Tapatalk
Old 01-12-2019, 11:12 AM   #6
IllusionX
There is still a few videos on YouTube I guess..
https://m.youtube.com/watch?feature=...&v=qbInNKKEwFc
Old 01-12-2019, 05:48 PM   #7
siman338
Drives: Yaris mk3
I can't find any guide in the forum!
Thank you for the immediate response!
Old 01-12-2019, 05:50 PM   #8
IllusionX
There isn't any guide. It was done and it also needed a micro controller made by CTScott to work.
I believe the ECM doesn't have what it needs to control everything, and also the mechanical switch is now electronic
Old 01-12-2019, 06:01 PM   #9
microimage is a now defunct competing forum on which the undertaking of manual to digital HVAC was documented. Too bad since it had outlined the trials and tribulations of the conversion in great detail.
Old 01-12-2019, 06:11 PM   #10
siman338
Drives: Yaris mk3
As i can understand this forum is off... Am i correct?
DIY - Steering Wheel Head Unit Control Buttons Seion DIY / Maintenance / Service 3 04-26-2017 03:49 PM
Grrrrr! Cruise control....MPG wrecker Gogogordy Fuel Economy Forum 8 09-16-2012 05:00 PM
Lower control arm replacement 2005 Echo ? Infinitrium Wheels, Tires and Suspension Forum sponsored by The Tire Rack 1 06-27-2012 03:23 PM
