Old 09-06-2007, 12:17 PM   #1
Canadian
Drives: yaris
car shaking after servicing
My friend has a 2000 Yaris and it was running perfectly when she took it in for servicing. The service center was a Toyota service center that has excellent work in the past. They said that they replaced a steering wheel belt. When my friend drove the car the next day, the car was shaking violently, She drove for 20 km and then had to call the service shop to get the car. They said that there was nothing wrong with the car but when she drove it it continued to shake. She called the service center again and they came out but this time when the service mechanic drove with her, the car stopped shaking and has not been shaking since then. This happened yesterday and my friend is afraid to drive her car. Does anyone have any idea what may have happened?
Canadian is offline   Reply With Quote
Old 09-06-2007, 08:54 PM   #2
Nibs
Nibs's Avatar
Drives: 07 Yaris HB black
2000 yaris?
Nibs is offline   Reply With Quote
Old 09-06-2007, 09:06 PM   #3
ECHOKnight2000
Small Car Lover
ECHOKnight2000's Avatar
Drives: A Super Car
Originally Posted by Nibs View Post
2000 yaris?
Yes he is referring to the first gen Yaris that wasn't sold in the U.S. At least the hatchback. The later hatch models first gen were sold in Canada for two years as the ECHO hatch now replaced by the current Yaris.
I don't what to say. It could be a bent rim or mis-alienment but if the shaking stops I don't what it is. Be pursistant. Is the skaking when you speed up or slow down or when ever the car moves? What service did they perform? Routine maintance?
You may look good on the beach but in reality you're a pompus, egotistical jerk. "I was never on the beach with you..."and you never will.
ECHOKnight2000 is offline   Reply With Quote
Old 09-07-2007, 09:23 AM   #4
Nibs
Nibs's Avatar
didn't see the Istanbul part :)
Old 09-07-2007, 09:41 AM   #5
YarisTom73
46 and 2, just ahead...
YarisTom73's Avatar
Drives: 07 Yaris sedan
Ghost in the system..find a great priest to bless the vehicle
Truly odd situation. Check for mud buildup inside the wheels?
YarisTom73 is offline   Reply With Quote
Old 09-07-2007, 11:19 AM   #6
static808
Engineer/Artist/House-Dad
static808's Avatar
Drives: 2006 Toyota Sienna XLE
i agree, shaking, vibrations or shimmies tend to be associated with un-balanced wheels and mis-alignments. but these things dont mysteriously go away, so i have no idea what may have caused her "temporary" shaking...
--B
His: 2006 Toyota Sienna XLE Arctic Frost Pearl, FC Package, 2007 Solara Nav unit, Spoiler, Running Boards & Auto-dimming rear mirror
Hers: 2007 Toyota Yaris LB Black Sand Pearl, Auto, Power Package, Side Airbags, VIP security, USDM center armrest, and accessory 7 spoke 15" alloy wheels
static808 is offline   Reply With Quote
Old 09-26-2007, 08:52 AM   #7
ddongbap
Did you see if your lugnuts are tightend properly?
Old 09-26-2007, 09:53 AM   #8
BailOut
Steals terrorist's lunch
BailOut's Avatar
Steering wheel belt? Does the 2000 Yaris use hydraulic power steering instead of electrical?
Regardless, the things that have been mentioned are what should be looked at. Changing a belt, or even a failed p/s pump, will not cause that kind of shimmying/shaking. Only something from the axle outward can do that.
The lug nuts are the first thing I would check, especially since the problem seems to have corrected itself (this points to it being an easily serviceable part... it's not like a warped axle straightens itself back out). It's easy to miss tightening one nut if you're in a hurry and even if they hit all of them there's the chance that one or more wheels didn't seat to the hub properly at installation time.
- Brian
Share the Road
Old 11-25-2008, 04:43 PM   #9
worlocksmith
Drives: 2008 yaris
It's not the lug nuts, they make a knocking sound. Odds are a mechanic left a tool in the engine bay and it got caught on a tie rod, or it could have been stuck to a pulley, but then it shook free prior to the mechanic riding with her.
worlocksmith is offline   Reply With Quote
Old 11-25-2008, 05:38 PM   #10
May sound odd, but check the spark plug sequence and make sure they are on the right plug. One trick the dealers will do is purposely switch two plugs so that you bring it back for more unwanted work. This exact senario will cause your car to shake like hell.
Old 11-25-2008, 05:38 PM   #11
Tamago
Start another Oil Thread!
Tamago's Avatar
Drives: ZZW30
sounds like a bad CV axle ;)
Old 11-25-2008, 05:40 PM   #12
That's a bitch getting the bearings pressed, lol, but the good thing if it is the CV, you're parts will be cheap since they are ready available.
Test Car needed for BlueBat overlays Turbo&Auto General Yaris / Vitz Discussion 12 07-24-2009 02:35 AM
My New Yaris (First Car), About me, and my TSB Questions dlinkwit27 DIY / Maintenance / Service 1 06-03-2007 12:34 PM
How to Be a Street Racer - General Life Guide MDF Off-topic / Other Cars / Everything else Discussions 7 03-19-2007 12:49 PM
Gasoline Car Wash Machine elsteverino889 Wash, Wax, Detailing, Exterior Repairs 1 02-22-2007 02:59 PM
New car shopping - long post littlecarlove General Yaris / Vitz Discussion 19 11-01-2006 10:58 PM
