Old 06-23-2019, 10:40 AM   #1
jmandawg
Drives: 2007 Yaris
2007 Yaris airbag light won't reset code 52
I had to take apart my dashboard to replace the upper passenger glovebox. Part of the disassembly was removing the passenger airbag. I did some driving around with the airbag removed from the car, when i put everything back together the airbag light is now permanently on.
As described in other posts, I shorted the ODB pins to get the code which is "52", I also did the reset procedure which seemed to work (constant flashing light), but once i turn the car off and back on, the light is back solid.
Any suggestions?
Thanks.
jmandawg is offline   Reply With Quote
Old 06-23-2019, 12:22 PM   #2
jmandawg
Drives: 2007 Yaris
Turns out one of the connectors want pushed all the way in into the airbag. Fixed now.
Old 06-24-2019, 11:42 AM   #3
ern-diz
ern-diz's Avatar
Drives: 2007 Liftback
That was going to be my only suggestion
Glad you got it sorted without much trouble.
On Instagram
On Wheelwell
2008 Toyota Yaris airbag light ON Temeku DIY / Maintenance / Service 0 10-22-2016 08:02 AM
Replace airbag in my 2007 Yaris uglyducklin DIY / Maintenance / Service 2 01-12-2011 02:53 PM
TSB's WD-40 General Yaris / Vitz Discussion 27 06-06-2007 01:11 AM
