Old 02-25-2015, 07:59 AM   #1
jmandawg
Drives: 2007 Yaris
What is this that the oil is leaking from? [pic]
2007 Yaris hatchback with automatic transmission.
This is under the engine where the engine meets the transmission, on the engine side. Looks like a plastic cover that's leaking oil. Not sure what is behind it. Hopefully it is easy to fix.
jmandawg is offline   Reply With Quote
Old 06-03-2018, 12:23 PM   #2
Redhawke1780
Drives: 2007 Toyota Yaris
Did you ever find out what this leak was about ? My wife's 2007 Yaris just started leaking in the same spot.
Redhawke1780 is offline   Reply With Quote
Old 06-03-2018, 12:39 PM   #3
tmontague
tmontague's Avatar
That is a window that allows you to inspect the clutch or pressure plate. It is also a way to show you have a main seal leak so the oil doesn't just pool in that area (sort of like a wrap hole on a water pump).
Its likely that the main seal is leaking oil
Old 06-03-2018, 03:36 PM   #4
komichal
That is interesting, I never knew that there is this inspection hole there. Shall I just pry that rubber off with a screwdriver and peek in? How can I recognize that the pressure plate or the flywheel are bad?
Old 06-03-2018, 03:59 PM   #5
tmontague
tmontague's Avatar
Iirc it's plastic and you cannot realy tell if the pressure plate is bad per say but you will be able to see if the main seal is leaking which would be from behind the pressure plate
Yaris Oil Change DIY rningonfumes DIY / Maintenance / Service 91 01-11-2019 07:18 PM
***The Engine Oil Bible*** Hussain-Vtec Performance Modifications 20 09-28-2016 02:47 PM
A Mystery Oi'll Say! Yar Is Word Fuel Economy Forum 16 05-11-2013 04:22 AM
Motor oil debate - interesting info but a long read. mikeukrainetz General Yaris / Vitz Discussion 6 12-10-2006 08:16 PM
