Old 03-31-2013, 08:09 PM   #1
theyaris123
Drives: yaris 2007 3dr hatchback
cargo light not working? ( Yaris HatchBack )
Hi, my trunk light (cargo space) is not working. i changed the bulb but it still not working. I wonder where the problem is ???
( my dome light and all accessories are working just fine )
theyaris123 is offline   Reply With Quote
Old 03-31-2013, 08:32 PM   #2
andulong
andulong's Avatar
Drives: 2008 Hatch Red
Could be a bad switch. When I open my hatch it shows up on the dash as a door open. Is yours doing this? Did it used to? Might check the switch.
andulong is offline   Reply With Quote
Old 04-03-2013, 01:36 AM   #3
theyaris123
Yah, when i open the hatch, there is no door open signal show up on the instrument panel. if it's the switch, where is it? i cannot find it, so i don't know where to fix?
Old 04-03-2013, 08:29 PM   #4
andulong
andulong's Avatar
Good question. I just went and took a look at mine. It has to be built into the latch. I poked around in there but couldn't activate it. Your switch might be stuck in the open position so a little lube and a few openings and closings of the hatch might be worth a try. It doesn't look too hard to pull it out but I didn't feel like doing that.
Old 04-03-2013, 08:44 PM   #5
It is part of the latch. The brown wire is one side of the switch and the white/black wire, which is ground is the other side.
Old 04-05-2013, 05:39 PM   #6
theyaris123
Thanks you for the answers. i will try to check that when i have time. hope it's not too hard to open the hatch panel to fix it.
Old 04-19-2015, 12:38 AM   #7
ucsmfu
Drives: yaris le
how would I go about fixing this brown wire for the switch ?
Thanks
ucsmfu is offline   Reply With Quote
Old 05-22-2017, 03:49 AM   #8
JSCIII
Drives: Yaris Hatchback 3 Door USA Ver
Scott! do you have any diagrams for this by any chance? I have the exact same issue and although I pulled out all of the covers from my Yaris hatchback, I can't find the culprit
JSCIII is offline   Reply With Quote
Toyota Yaris Battery Light On - Repair gabo General Yaris / Vitz Discussion 1 08-24-2011 07:21 AM
test fit 06-07 Yaris 4 door fog light winson California 15 01-13-2009 08:25 PM
