Old 02-16-2010, 04:13 PM   #1
Salo
Drives: Yaris 09 HB 4 door
need an answer asap
would wheels with bolt pattern 4x100/4x114.3 fit my 2009 hatchback??
SaLo
Salo is offline   Reply With Quote
Old 02-16-2010, 04:19 PM   #2
4x100 yes, 4x114.3 no
Check the tire/wheel section - There is a lot of info about what offsets will/won't work as well.
Old 02-16-2010, 04:32 PM   #3
Salo
i can't find the second pattern.
im not sure how to read it! :x
SaLo
Old 02-16-2010, 04:37 PM   #4
I am not 100% sure what you mean, but the patterns read as number of lugs x diameter.
4x100 is the correct pattern for Yaris. 4x114.3 will not fit.
Old 02-16-2010, 04:38 PM   #5
Salo
the post says 4x100/4x114.3 so im very confuseedd
SaLo
Old 02-16-2010, 04:54 PM   #6
dean_park
Drives: 2011 VW Golf TDI
Originally Posted by echo_hrs View Post
It might be a dual drilled wheel...
Cheers
This is normal. As long as it says 4x100 you are fine. The 4x100/4x114.3 usually has another set of holes which are drilled around the 4x100, so you'll see 8 lug holes... What's the post? We could probably see better if you showed us the wheel.
dean_park is offline   Reply With Quote
YarisBueller (admin) please answer your PM and emails TWM Performance Suggestions - Feedback - Questions 17 10-05-2009 12:35 PM
Please Help... ASAP!!! Kamikaze1987 DIY / Maintenance / Service 9 09-08-2009 02:48 AM
Gotta get these out ASAP! gwasabi Items for Sale by private party 13 07-08-2009 10:19 PM
Radiator cap.... answer asap if possible Jerkratt Cosmetic Modifications (Exterior/Interior) 12 06-10-2007 10:59 PM
