Old 08-28-2018, 11:14 PM   #1
timbstir
Drives: 2010 Yaris Seden
MT Plug Crush Gasket
I have a 2010 Yaris with a 5-speed manual Transmission. Getting ready to do a drain and fill of the tranny oil and was hoping to pick up a new crush gasket. Was wondering if anyone had a part number or anything to help me find one.
timbstir is offline   Reply With Quote
Old 08-30-2018, 03:34 PM   #2
B.B._07
Drives: 07 5dr
If the crush washer isn't leaking now then I wouldn't worry about replacing it when you change the transmission fluid. Officially the crush washer is one time use but in reality you can reuse as long as it hasn't been over-tightened before.
Old 08-30-2018, 03:55 PM   #3
bronsin
bronsin's Avatar
If the gasket is rubber coated use it. Wifes Camry with 161k has the origional drain plug gasket. No leaks.
Copper crush washers are obsolete.
Old 08-30-2018, 10:27 PM   #4
timbstir
Good to know that the OEM gasket isn't copper trash. Service Manual says to replace so I was concerned.
Old 08-30-2018, 10:32 PM   #5
tmontague
tmontague's Avatar
You should be fine reusing it like other stated. I've done plenty of drain and fills on mine and have never had any leaks and I've never replaced the washer
crush washer on drain plug? 2007yariz DIY / Maintenance / Service 15 06-08-2023 02:09 PM
Wires Inside the Yaris & What They Do The Architect DIY / Maintenance / Service 149 10-18-2022 03:32 AM
DIY: CHANGE MANUAL TRANNY OIL ttufrosty DIY / Maintenance / Service 157 09-07-2018 01:43 PM
bit of spark plug insulation may have fallen into cylinder alagappan the proud DIY / Maintenance / Service 20 01-09-2014 06:10 PM
Oil drain plug gasket question schleppy DIY / Maintenance / Service 7 04-17-2009 05:35 AM
