Old 05-25-2013, 08:50 AM   #1
poida
Drives: yaris yrs 2007
metallic noise when accelerating
Hi all,
I've got a 2007 Yaris 1.5 5dr automatic hatch (105,000km on odometer) and i've got some weird noise when i'm accelerating. Sounds like ball bearings rattling in a can, or some bearing noise. It's very inconsistent, some days it's really loud and some days it's very faint.
- The noise happens when going up hills, around 1500-1700rpm when accelerating
- Seems to only sound when there's a certain load on the engine, if i accelerate very slowly there's no noise
- noise happens at any speed, accelerate from standstill, and crusing at 50km/h then accelerating hard etc.
- coasting (any speed) or braking and the noise doesnt exist
- revving the engine in neutral there's no noise
- checked alt/ac belt, it's in good condition and tension is good, also checked the pulleys, no major sounds/play when rotating without the belt.
anyone have any ideas? Thought it was pinging and tried a higher octane fuel (no difference). Seems to be related when the engine moves when accelerating???? Been looking on previous posts, could it be the exhaust donut gasket between the manifold and front pipe?
poida is offline   Reply With Quote
Old 05-25-2013, 11:48 AM   #2
yaris1F8
yaris1F8's Avatar
Drives: Yaris 1F8
Heat shield, vacuum leak @ throttle body... im pretty sure its nothing serious..
Check for vacuum leaks..
yaris1F8 is offline   Reply With Quote
Old 03-29-2015, 12:10 AM   #3
Mikastef
Drives: Yaris
Hi poida . Here is my post http://www.yarisworld.com/forums/showthread.php?t=54069
Did you sort out your problem?.
Mikastef is offline   Reply With Quote
Old 03-29-2015, 12:20 AM   #4
Exiwolfman
Exiwolfman's Avatar
Drives: 2007 Yaris
Heat shield over catalytic converter
Compilation of Yaris TSBs eTiMaGo DIY / Maintenance / Service 70 12-13-2016 12:17 PM
Whirring Noise when accelerating RatedRVD DIY / Maintenance / Service 11 06-06-2012 12:07 PM
drivetrain is making funny noise while accelerating whoknows89 DIY / Maintenance / Service 0 02-09-2012 04:28 PM
Help With Reverse Noise???? JoshW DIY / Maintenance / Service 0 09-09-2011 12:27 PM
Strange Noise when accelerating! cybertees DIY / Maintenance / Service 22 05-24-2009 08:37 PM
