03-27-2019, 01:50 PM | #73 |
Drives: 2008 yaris 5dr hatch Join Date: Apr 2016
Did a mock up, I scaled the 2 in the pic until the small was the same as the old tire so this is close to what the new tires will be like!
03-27-2019, 01:57 PM | #74 |
These are the flare I was thinking may be good as they follow however you cut.
https://www.amazon.ca/dp/B0794BXHSQ/...4-339eef22020c |
03-27-2019, 02:00 PM | #75 | |
3 Yaris and counting..
I'd be worried about structural damage cutting that much!
03-27-2019, 02:05 PM | #76 |
Paint isnt perfect fir sure. I bet it wont be that drastic
03-27-2019, 02:28 PM | #77 |
Drives: 2008 Toyota Yaris 5dr Liftback Join Date: Jul 2012
You guys will be able to get away with much more rear wheel cutting than us four door hatch drivers. We’d have to end up cutting into the doors haha.
I know that in place of all terrains some Subaru guys run chunky winter tires such as the Firestone Winterforces. They have a relatively aggressive look to them and would be available in sizes smaller than the 27” grabbers.
Hot Rhonda 2008 Toyota Yaris 5dr Liftback - Bayou Blue - Cosmo Racing Short Shifter - Kenwood Single DIN Aftermarket Headunit - Rockford Fosgate Punch 6.5” Speakers “the dents make her handle better.” |
03-27-2019, 02:38 PM | #78 | |
04-02-2019, 11:51 AM | #79 |
Drives: 06 2ZR Turbo Yaris RS Join Date: Aug 2017
What a beast, she'll be! Pumped to see the final effect.
04-02-2019, 12:34 PM | #80 |
Still lots of steel to grind out on the front lift. It'll happen soon lol
04-20-2019, 06:29 PM | #81 |
Drives: Yaris hatchback 06 Join Date: Nov 2018
Update?
04-20-2019, 10:43 PM | #82 |
The rear spacers are holding beautifully. Probably 7-9000 km and everything seems great.
Im about half way done the front. I had to buy an electric die grinder. I settled on a rotozip. Was about half the price of an electric die grinder with variable speed. Its basically a dremel but 4 times the size and power. Hopefully can handle the job unlike the mastercraft rotory tool. Im hoping in the next 2 weeks ill be ready to install the front lift. Ive been working out of town and thats been slowing progress down.
04-26-2019, 12:57 PM | #83 | |||
ground to pinch weld. Front: 8.25" and rear: 8.75" Quote:
If I were to stay with a 25" or so tire, I'd look into rally tires. Still haven't found a "regular" all terrain type tire. Then again, do an eBay search for all terrain 195/75-r14, and you'll see some pop up. I'd personally stay with 14" wheels in order to keep the weight down a bit. Maxxis Tires have both a mud terrain (Buckshot Mudder) and all terrain (Bighorn MT-762) at a 27x8.5-14 size. Though the specs list them at 26.6" and 26.3", respectively. |
04-26-2019, 01:25 PM | #84 |
04-26-2019, 06:29 PM | #85 |
04-29-2019, 03:26 PM | #86 |
Updates! Post #2
04-29-2019, 03:50 PM | #87 |
Those look good. I thought about something like that but didn't need that much height so went from the top. May re-think it after I see yours installed.
04-29-2019, 06:37 PM | #88 |
Thanks! I'm not a machinist by any means. And it isn't easy to drill large holes in 1/4" flat stock perfectly spaced and aligned without a large drill press. I ended up drilling smaller holes and ground them out with a carbide burr on a rotozip. All in all, there was 4 lift plates (long ones on the ends), 12 spacer plates to make, and 40 holes to drill and grind out. I'll report back when it's all installed. Honestly not sure when that is. Back out of town tomorrow for work.
04-29-2019, 07:51 PM | #89 |
Understood. I make do like that too. We look forward to the progress however slow it has to be. Im no better. My other crap keeps breaking down and taking my shop time.
Sent from my moto e5 play using Tapatalk |
04-29-2019, 10:26 PM | #90 |
Amen!
Thread Tools | |
Display Modes | |
Similar Threads | ||||
Finally bought a lift | CTScott | DIY / Maintenance / Service | 26 | 09-28-2010 09:09 AM |
zage turbo kit..! just need some help | joseyaris | Forced Induction Forum | 12 | 10-29-2009 08:35 PM |
Greddy xB kit vs Greddy Fit kit | ellenbetty | Forced Induction Forum | 52 | 09-29-2009 08:42 PM |
Xenon-Vision HID Conversion Kit - $120 Shipped/$160 Shipped for Slim Ballast | phu@xenon-vision | Sponsors Classifieds Area | 8 | 03-06-2009 02:33 PM |
