Old 12-07-2018, 08:48 AM   #1
KurtRS
Drives: 2005 Echo RS 2D Hatch
15 x 7.5 et 30
Aiming to get the closest to factory ride height with a stretched tire look.
My goal was looks and fuel economy.
Thinking of running a 175 65 15 tire.
Any recommendations on that matching the 185-60-15 on my 2007 yaris rs?
Will likely be lowering the car in the future as well.
https://www.1010tires.com/Wheels/Kon...White/Machined
These are the rims I picked up last night.
Test fit and no rubbing issues. The lip just sticks out past the edge of the car on the front.
KurtRS is offline   Reply With Quote
Old 12-07-2018, 08:35 PM   #2
Stretched tires are dumb.
If you lower the car, you will likely rub.
Old 12-08-2018, 03:39 PM   #3
kevinj93
kevinj93's Avatar
Drives: 2013 NCP130
How you want your car to look is a personal choice. If you want a particular look, go with it, but be prepared to put up with any negative effects from it.
Stretched tyres are very popular in drifting circles. They wouldn't be doing it if it didn't work for them, but maybe the tyres they are using are made to be used on wider rims.
Most tyres are designed to fit a certain rim width, and the makers generally have listings of what size rims the tyres are designed for, as well as recommended maximum and minimum recommended rim widths. Stretched tyres will probably wear unevenly with the sides of the tread wearing faster. The grip levels could also be affected. If you are gojng to go this route, try and find a tyre shop that has experience with stretched tyres to see what brands and sizes they recommend.
Running on standard AU 14" steel wheels (14x5 rims, 175/70R14 tyres). Added reversing camera and touch screen radio, cruise control, 16" rear wiper blade, tow bar and dash cam.
kevinj93 is offline   Reply With Quote
Old 12-08-2018, 04:09 PM   #4
Ronnie V
Drives: 04 3dr HB and 04 5dr RS
+1
Ronnie V is offline   Reply With Quote
Old 12-08-2018, 04:22 PM   #5
DarkShadowFox
Originally Posted by Ronnie V View Post
+1
+2
Old 12-09-2018, 06:17 PM   #6
KurtRS
Apparently I need to change how this is written.
175 series tire is almost 7 inches wide. So using the word stretched is not really what I am doing. I like the tread to be a little less then the rim width.
I would go coil overs so likely would only go down an inch.
The main focus of this post was to get the overall diameter the same as factory.......
Old 12-09-2018, 07:04 PM   #7
kimona
kimona's Avatar
Drives: 2014 White VITZ
175mm tyres fit wheel width 4.5"-6.5". I wouldn't stretch them onto 7.5" wheels... but that's your choice.
I'm quite conservative about wheel and tyre fitment and camber adjustment. The minimum tyre width I'd put on a 7.5" rim is 205mm. But, with et30 you're going to poke ugly up front unless you add camber.
Plus, you're going to have serious issues up front if you lower, unless you add camber to reduce rubbing.
185/60/15 = 23.7" overall diameter (OEM)
205/50/15 = 23.1" recommended size if you plan to lower
205/55/15 = 23.9"
Old 12-09-2018, 09:22 PM   #8
suprf1y
suprf1y's Avatar
Drives: 05 Echo
https://www.tacomaworld.com/tirecalc
suprf1y is offline   Reply With Quote
Old 12-09-2018, 11:08 PM   #9
KurtRS
Originally Posted by suprf1y View Post
This is the same as the tire calculator I use. Does not take into account the rim width.
This is why I was picking this tire size. Think I would lose the 1% bigger diameter in the sidewall with the wider rims.
https://www.willtheyfit.com/index.ph...7-5&offset2=30
Old 12-10-2018, 01:10 AM   #10
kimona
kimona's Avatar
Look at the "Official YARIS Wheel & Tire Guide" here:
http://www.yarisworld.com/forums/showthread.php?t=5021
Scroll down and you will find this link to an excellent wheel and tyre fitment guide:
http://www.rimsntires.com/specspro.jsp
Old 12-10-2018, 07:25 AM   #11
KurtRS
I read the tire guide top to bottom.
This tire calculator also not allow 175 tire on 7.5" rim and also does not associate different rim widths to affect overall tire diameter.
I think I am going to buy a used tire and try it on to measure it.
Old 12-12-2018, 01:28 PM   #12
stretched tires are dangerous.
and last time i checked, roads in NF arent great. you're just looking for trouble.
7.5 too wide? Pinchlite Wheels, Tires and Suspension Forum sponsored by The Tire Rack 17 09-15-2018 09:04 PM
Can it fit?? 17 - 7.5 ET 35 Mad$ Wheels, Tires and Suspension Forum sponsored by The Tire Rack 7 04-24-2018 06:22 PM
XXR 508 18 x 7.5 JumpmanYaris Items for Sale by private party 35 09-08-2011 06:37 PM
enkei nt03+m 17x 7.5 turboyaris Items for Sale by private party 2 01-19-2009 01:27 PM
RIn 7.5 Vs 7.0 Rudeshady Central and South America 2 12-21-2008 01:51 PM
