Old 02-27-2020, 01:41 AM   #1
RMcG
Drives: 2008 Yaris Base Hatchback
Blower motor started making noise a few days ago
It is kind of a low pitched noise, that is lower pitched than the usual "air blowing noise" that is heard when the fan is on. And this low pitched noise is loudest on speed 4 (the most air), not as loud on 3, and really not noticeable on 2 or 1.
The blower fan is still blowing air, a good thing, because I need the defrost capability; it's critical. I could survive, perhaps uncomfortably without much heat in the cab. I'm concerned that the blower may stop working suddenly. Should I do anything? Is there anything I can do to prevent the blower fan motor from just stopping working altogether?
Thank you,
R.
RMcG is offline   Reply With Quote
Old 02-27-2020, 02:06 AM   #2
NYC-SE
NYC-SE's Avatar
Drives: 2014 Yaris SE
Perhaps a leaf, piece of paper, etc. made its way into the fan. I have had that happen before (but not on the Yaris). If that is the case it really doesn't harm anything but is annoying as hell. Sometimes it will work its way free or you can disassemble the dash and try to clear it manually. Not fun.
Alternatly it could be the blower motor bearings going bad. If so it will get progressively louder. And again you would have to disassemble the dash to remove and replace the blower.
NYC-SE is online now   Reply With Quote
Old 02-27-2020, 10:53 AM   #3
stykerdk
Yaris Hybrid Limited 2015
Drives: yaris Hybrid limited 2015
Just pull the cabin filter out, then you can look right in the blower and check it for leaves and other debris.
And also turn it by hand to check its running free.
Its simple to change it in a yaris just look up in the footwell in the passenger side.
Three screws and unplug it.
C-HR 1,8 Hybrid premium 2020
stykerdk is offline   Reply With Quote
Old 02-27-2020, 11:37 AM   #4
You can of course check for a foreign object but my guess, based on the fact mine has been noisy for a few years, is that it is just aging.
Old 02-28-2020, 07:58 PM   #5
RMcG
OK guys,
Thanks for the advice. I see that there are a couple of youtube links for changing the indoor cabin filter, example: here . I have never changed this filter. Maybe it does have debris in it.
Does anybody have any suggestions as to where to get a new filter or blower?
Thanks,
R.
Old 02-29-2020, 06:28 AM   #6
BLH
Drives: 2007 Yaris Sedan
You may also find their is no cabin filter in the blower housing. Letting foreign objects to get into the blower housing.
My 2007 shipped with no cabin filter in it. Just the empty filter space where it is designed to fit.
I got my cabin filter at a local auto parts store.
BLH is offline   Reply With Quote
Old 02-29-2020, 08:20 AM   #7
ex-x-fire
If anything Walmart carries those filter too.
Old 03-01-2020, 10:15 AM   #8
BIGTAZ351
147K-Blue / 24K-Yellow
BIGTAZ351's Avatar
Drives: 2010 Ylw 3dr. AT(Blue-Wife's)
Mine on my 2010 Blazin Blue car started "chirping" at 91K which is common of electric motors, I replaced the HVAC fan, it was $70 on Rock Auto for the assembly...and its pretty easy, once you take the lower glove box out on passenger side...
All Weather Package, Power Package, Cruise, WeatherTech Floor Mats. Altimax Arctic Winter Tires.
Repair List:
1 new blower motor, making funny noise. @ 91K (Water pump @ 120K)
Mod List:
1. Black tape on most of the annoying blue high beam light behind the lens. (thank you CTScott)
BIGTAZ351 is offline   Reply With Quote
Old 03-02-2020, 12:18 AM   #9
SECProto
Drives: 2012 Yaris LE
I had this issue last fall, pulled out the filter and saw some rodent had made a nest above the air filter (gross!)
fix was easy - open glove box, squeeze in sides to remove, pull out air filter and replace, unscrew the white housing for the blower and vacuum out any foreign debris i could see. Been working fine ever since!
SECProto is offline   Reply With Quote
Old 03-02-2020, 04:24 PM   #10
RMcG
Thanks to everybody for the advice. I plan to look at the filter on Wednesday. Good to know that it is easy and not too expensive to replace the blower fan. The noise is intermittent, so I am hoping it is a leaf or something. I will let you know. I wonder if the filter can be washed and then put back in, at least temporarily.
If it is a bearing that is shot, I wonder if they rebuild these fans/motors. I hate to throw stuff away that can be fixed without too much trouble, although my guess is the blower is mainly metal that can be recycled.
Thanks again for the advice, I get so much from you guys! You help me be self-sufficient and save money.
Isn't this forum great?!
R.
Old 03-03-2020, 11:47 PM   #11
SECProto
If the blower fan itself is gone, which is unlikely, you'd likely want to replace it - could easily get one from a junk yard if it's not damaged.
That is unreasonable (unless you have an after-market filter that is designed to be cleaned). Filters are made of a fine material, when they're done it's because there's too much dirt trapped in the weave of the material, blocking airflow. The filters aren't designed to be backflushed. If the filter is dirty, just buy a new one, they are not expensive:
https://www.amazon.com/EPAuto-CF1028.../dp/B014TYRQUY
Old 03-04-2020, 09:26 AM   #12
komichal
So guys - do I need to take off the dashboard to replace the blower or not? :)
Mine Yaris is 2007 hatchback...
Old 03-04-2020, 09:04 PM   #13
RMcG
I just looked at the filter by removing the lower hinged glove box compartment (passenger side of course). When I checked the cab filter compartment there was nothing there. Interesting since I bought the car new from a Toyota dealer 11 1/2 years ago. So it is possible to ride around without a cab filter for many years. I wonder why Toyota never put in a cabin filter.
Komichai, in answer to your question this link shows how to take out the blower fan in a 2007 Yaris. You have to remove a panel under the dash board, but not the dashboard itself.
R.
Old 03-05-2020, 08:17 AM   #14
komichal
Thanks RMcG!!!
Old 05-28-2023, 04:46 AM   #15
rayfloyd170
Drives: Yaris 2016 1.3 Manual
if it is intermittent and tapping it will make the low-pitch noise go away then the motor is almost due for replacement. just time will tell when it will stop
rayfloyd170 is offline   Reply With Quote
Old 06-07-2023, 02:22 AM   #16
IndestructibleYaris
Mine made a noise same problem and a napkin had got sucked into the blower wheel somehow. It was very easy to pull out. The lack of cabin air filter caused my problem
IndestructibleYaris is offline   Reply With Quote
Old 11-08-2023, 02:45 AM   #17
rayfloyd170
i just replaced with a new denso part and fixed the old one. I didnt know prior that this can be eternally repaired. :) could have saved a lot of bucks.
LINK ON REPAIR
https://www.yarisworld.com/forums/sh...657#post843657
Tags
blower motor, noise
My car is making a strange noise, and it's only 4 months old... Ktszeligo General Yaris / Vitz Discussion 4 12-26-2010 06:13 PM
Exhaust making lotta noise &itain't aftermarket! Yawesh General Yaris / Vitz Discussion 9 12-16-2008 05:20 PM
Yaris making knocking noise Wass General Yaris / Vitz Discussion 5 12-02-2008 03:37 PM
A/c blower motor noise!!!! LBdriver General Yaris / Vitz Discussion 28 09-12-2007 07:46 AM
Just got my Yaris two days ago. PolrWht07 New YARIS Purchase Forum 7 05-16-2007 06:11 PM
