04-15-2012, 11:20 PM | #1 |
Drives: 2007 HatchBack Join Date: Apr 2012
Broke Part on Engine Changing serpentine belt.
Hey guys. I was breaking the bolt loose that holds the alternator tight, wrench slipped, broke a coil type piece that goes into the engine. The piece looks as if its a spring returned flow control valve, seems that it goes into the oil system. It goes straight into the block underneath the oil filler cap. It has an electrical plug with 2 pins. I've tried identifying it with parts manuals, with no luck. HELPPPPP!!!!!!!!!!!!!!!!!!!!!
04-16-2012, 01:09 AM | #2 |
advocatus diaboli
Sounds like OCV or oil control valve...they run about 100.00 from the dealer. People have a tendency to break them when working on the belt.
Does it look like this? http://www.yarisworld.com/forums/showthread.php?t=9364
-Type 07 FFL- My odometer 03/11 http://i205.photobucket.com/albums/b...a/2843ed85.jpg |
04-16-2012, 03:02 AM | #3 | |
Thanks. I've searched all OEM sites, cannot for the life of me find this damn thing. I need it something terribly. I have a Infiniti G37S to drive to work, but it likes gas alot more than my mighty 180k + miles EGG. Anyone know the part #? or have any information to help? My dealers are all dumb. So I see this being a problem. |
04-16-2012, 03:06 AM | #4 | |
And no, it does not look like that at all. It looks as if it is directly above that. It has a plug so I know it has a coil on it. It has a spool with a spring return on it. It looks as if it ports oil somewheres different when the coil is energized. The OCV isn't plugged up electronically is it?? Doesn't look like it per the drawing. Thanks |
04-16-2012, 03:12 AM | #5 | |
04-16-2012, 12:27 PM | #6 |
Does anyone know if this is correct part # for OCV??
15330-21011
It was 100.00 roughly from the dealer, but they gotta order it. So my car is dead until then. I was just curious if anyone KNOWS FOR A FACT THAT'S THE CORRECT # for the OCV in the picture mazilla provided the link for. Thanks. |
Similar Threads | ||||
DIY: Intake Installation | redyaris | DIY / Maintenance / Service | 53 | 08-23-2014 05:34 AM |
Engine Run-on changing 1st/2nd Gears | Ferret_san | General Yaris / Vitz Discussion | 4 | 09-06-2007 12:21 AM |
Does the Yaris' engine have a timing chain or belt? | grampi | General Yaris / Vitz Discussion | 8 | 05-12-2007 03:59 AM |
swap for 2zz-ge???? | yarisTOONR82 | Performance Modifications | 12 | 03-23-2007 07:15 PM |
About Engine Oil Changing Manual | hans_fh | DIY / Maintenance / Service | 4 | 03-03-2007 10:20 AM |
