08-20-2018, 09:13 AM | #1 |
Drives: 2009 Base Hatch 2 Dr Auto Join Date: Dec 2008
A trick to changing your battery
If you remove your battery the computer needs to relearn everything I learned when the battery was hooked up. I change the battery in my wife’s car at five years ago she go to work and it wouldn’t start. The computer had learned enough yet.
So there is a plug you can get that plugs into the OBD two terminal and there’s two alligator clips to hook a battery to. I use my tractor battery. This way the computer Always sees 12 V when the old battery is removed.Always sees 12 V when the old battery is removed. https://www.amazon.com/Outzone-Memor.../dp/B075WV4P7K
Synthetic Oil: Its All In Your Head Last edited by bronsin; 08-20-2018 at 09:43 AM. |
08-24-2018, 06:02 PM | #2 |
Drives: 2007 Yaris Sedan Join Date: Jul 2009
Thanks for the info.
Yaris - It's A Car ! |
08-24-2018, 11:11 PM | #3 |
Drives: 2013 NCP130 Join Date: Nov 2015
How long did it take to change the battery?
I don't know how long the ECU memory holds up for once the battery is disconnected, but most battery installers here use these devices to avoid having to put the security code into the car radio.
Running on standard AU 14" steel wheels (14x5 rims, 175/70R14 tyres). Added reversing camera and touch screen radio, cruise control, 16" rear wiper blade, tow bar and dash cam. |
08-25-2018, 07:28 AM | #4 |
Drives: 2010 yaris 3 door hatch Join Date: Jun 2013
Just be careful, the battery cables will still be live even though the battery is unhooked. I wrap the positive in a rag.
08-25-2018, 05:46 PM | #5 |
Good point. I hadn't thought about that.
08-27-2018, 01:21 AM | #6 |
I do not know how long it takes the computer to re-learn everything.
The only impact I noticed when changing the battery was that I lost all the saved radio stations. And the clock re-set too. Other than that - no difference. This tip you mentioned is useful for sure and I have heard that some cars even "forget" their security settings and you cannot get inside even with the original key after a battery is replaced. Which is crazy. Luckily for us, Yaris is not this car. Personally I disconnect my battery on purpose, whenever I work on the car. Just for security reasons. After all, it is an excellent opportunity for me to finally set the dashboard clock to exact time (as the dashboard clock in my Yaris slows down approx 1 minute per month). |
08-27-2018, 03:20 PM | #7 |
Maybe an hour from removal, travel to and from the store, and the actual installation.
12-23-2018, 10:30 PM | #8 |
Drives: Yaris 2008 Join Date: Dec 2018
I changed my battery yesterday and my car won't start anymore. How do I get the security code? And do I enter it in the radio?
Thanks Mel |
12-24-2018, 07:58 AM | #9 | |
Thread Tools | |
Display Modes | |
Similar Threads | ||||
We Have the Beats! | ern-diz | Photo-Video-Media Gallery | 41 | 05-15-2018 05:58 AM |
Electrical System Upgrade Advice | sqcomp | In Car Entertainment + Electronics (audio / video / alarm) | 6 | 03-23-2016 01:15 AM |
Battery keeps going dead | Outdoorsman | In Car Entertainment + Electronics (audio / video / alarm) | 6 | 09-09-2013 04:43 PM |
Ohm's Law and Setting Amp Gain | _S7V7N_ | In Car Entertainment + Electronics (audio / video / alarm) | 24 | 03-13-2012 09:34 PM |
