Old 03-22-2019, 03:36 PM   #1
flipside
Drives: 09 toyota Vitz
Suspension/ alignment
So, I had change my suspension from lower springs to coilovers. Before the changes, I have notice that the back right passenger side tire rubs in slight bumps. Haven’t done any alignment on the car even after the change to coilovers. It’s only the back right side does that. Had 17” wheels and recently went to 15x8 with 195/50/15 tires. The tires rubs more now with bumps. Wondering if it needs alignment? Or I can do it myself to adjust the cambering? Toke my car to flat surface and notice the back left has slight camber and the back right side is more angled outward from the top. Is this an easy fix or what can I do?
flipside is offline   Reply With Quote
Old 03-22-2019, 08:17 PM   #2
IllusionX
Drives: 07 Yaris Sedan Aero
The rear wheels are not adjustable. You can shim it for camber though.
Else, I've read a long time ago, the rear beam is never perfectly aligned, so if you have a tight fitment, then chances it would run one side, and not the other.
No factory rear alignment gear? bad DIY / Maintenance / Service 6 01-28-2015 12:21 PM
WOW What a difference an alignment makes!! YarisSedan Wheels, Tires and Suspension Forum sponsored by The Tire Rack 1 10-12-2009 05:29 PM
understeer DOMAV General Yaris / Vitz Discussion 31 09-30-2009 07:01 AM
Suspension alignment after new springs? mrrock Wheels, Tires and Suspension Forum sponsored by The Tire Rack 5 02-14-2007 01:05 PM
