Old 03-03-2018, 09:47 PM   #1
David C
Drives: White '07 3dr LB
Engine refresh ?
My brother took my car today and he said that the engine feels like its sluggish compared to his Yaris. I have to admit I kinda feel like it's been a little rougher/louder and the car doesn't seem as smooth as it uses to when I bought it 2 years ago. It has 210 000km, 2007 HB auto.
Last when I checked the spark plugs a few months back one was reaching end of life and the others were middle (clearance check). I never had the engine knocking or misfire, never any trouble at startup. Do regular 8000km oil change.
I'm thinking maybe new spark plugs, new intake air filter (been 1.5 years, but isn't dirty) and... that's about it that I know of I cane o myself. Not sure it's gonna do much tho. What about those injector or throttle body cleaning etc ?
Personally I have no problem at all with it, but maybe there's something the car could benefit from ?
David C is offline   Reply With Quote
Old 03-04-2018, 07:50 AM   #2
dogsridewith
Drives: 2007 2-door hatchback
Compression check.
Old 03-04-2018, 09:42 AM   #3
David C
Engine refresh ?
Originally Posted by dogsridewith View Post
Compression check.
I'll look it up.
Edit : Not sure my car actually has symptoms of something wrong with compression, never had misfire nor knocking, never had problem starting, never heard anything bad from the engine.
Old 03-05-2018, 12:46 PM   #4
Jeanseb29
Drives: Toyota Yaris RS 2011 (HB)
I would try cleaning the MAF sensor and the throttle body. You can buy both cans of cleaner at Canadian Tire for less then 20$. After that, disconnect the battery for a couple of minutes to reset the ECU. Once the battery is reconnected, start the engine and let it idle for 10-15 minutes. Drive for a day or two and come back here to tell us if you noticed an improvement :) - JS
Sent from my SM-N910W8 using Tapatalk
Jeanseb29 is offline   Reply With Quote
Old 03-06-2018, 07:26 AM   #5
dogsridewith
Compression
Originally Posted by David C View Post
I'll look it up.
Compression can be down 30 percent w/ none of those symptoms.
Old 03-06-2018, 04:14 PM   #6
06YarisRS
Drives: 06 2ZR Turbo Yaris RS
Take this advice. These are very simple jobs and can make a world of difference. This simple service both smoothed out my idle and generally made the engine run better through all rpm ranges.
motorbike engine swap ACKING_QC Performance Modifications 6 05-12-2021 03:08 PM
New Spark Plugs, Engine Light Appear grvdggr Performance Modifications 6 09-21-2015 09:34 AM
A Mystery Oi'll Say! Yar Is Word Fuel Economy Forum 16 05-11-2013 04:22 AM
Remote Engine Start PT398-33070 Reeves360 In Car Entertainment + Electronics (audio / video / alarm) 3 08-26-2009 07:11 PM
