Old 03-16-2010, 02:38 PM   #1
DIY - How to remove or insert a pin on the ECM Connector A21
This DIY is primarily for those needing to know how to add the pin to position 40 of the ECM connector A21 for the DIY cruise control on 2006-2008 Yaris.
Note: It is always a good idea to disconnect the battery when working with the ECM wiring.
A. Release the ECM Connector.
1. Push the release button on the end of the connector latch with your fingertip. You will feel a slight click and will then be able to lift the arm:
2. Lift the latch arm from horizontal to vertical. It will move easily at first, then will require a bit more force as you near the vertical position:
3. As the latch arm nears the vertical position, the connector will lift slightly off of the ECM:
4. You can now remove the connector to work on it. To obtain full access to the pins, carefully snip the cable tie from the rubber wire protector and remove it.
B. Remove a plug
1. To remove a sealing plug, insert a stiff wire (paper clip, sewing needle, etc.) into the hole on the ECM side of the connector.Pin 40 - Plug still in.jpg
2. Push the object and the plug will begin to push out of the wire side of the connector.
3. Once the plug is out, you are ready to insert a terminal in its place,
Old 03-16-2010, 02:40 PM   #2
C. Release the connector pin lock before inserting the pin
1. Release the connector pin lock, by lifting the white plastic piece. I find it easiest to push it from the opposite side than to pry it up:
2. Here is the other side with it released. The white part is raised about 1/8" from the locked position:
D. Inserting a pin
1. Here is a "repair terminal" ready to be inserted. Note that the pin has a "flat" bottom and and "open" top. The pin must be inserted in the correct orientation, or the connector pin lock will not click back into place.
2. Insert the pin as shown below. Note that in this picture the open top of the connector pin is oriented down.
3. The pin should insert will very little force. If it will not go, lift it and try again. If the orientation is correct, the pin will slide all of the way in and will click into place.
E. Lock the pins in place by pushing the connector pin lock back down. If it does not easily snap back into place, then the pin is not properly inserted.
Old 05-18-2010, 05:50 PM   #3
sk8manmike
sk8manmike's Avatar
Drives: 2007 Yaris 4d Sedan
This really helps dude, thanks!
sk8manmike is offline   Reply With Quote
Old 04-14-2014, 10:08 AM   #4
XXXXX
Drives: 2008 Yaris Hatch
Hi CTScott... Where does one obtain the terminal for this?
XXXXX is offline   Reply With Quote
Old 05-16-2015, 05:06 AM   #5
Secretblend
Drives: 2009 Yaris
Just wanted to bump this so this could be answered and make it easier for next person that is trying to find this information.
Thanks to all for helpful information provided to allow rest of us to do a DIY project.
Secretblend is offline   Reply With Quote
Old 12-03-2020, 11:09 AM   #6
yarisa07hatchi
Drives: yaris 07 hatchi
ya where did you get it from
yarisa07hatchi is offline   Reply With Quote
radio wire colors & alarm wire color reference guide battleversiontc In Car Entertainment + Electronics (audio / video / alarm) 43 06-06-2023 02:12 PM
Wires Inside the Yaris & What They Do The Architect DIY / Maintenance / Service 149 10-18-2022 03:32 AM
DIY (08' USDM LB): Interior Light Color Change revnull DIY / Maintenance / Service 37 05-21-2016 12:59 PM
Viper Alarm Install gwasabi In Car Entertainment + Electronics (audio / video / alarm) 28 08-11-2010 02:57 PM
