Old 08-04-2009, 01:17 PM   #1
soloecho2
soloecho2's Avatar
Drives: 2004 Echo HB
Dual Purpose Tires
I need to know what tires would be better for the street and lapping. Direzza Z101 at 195-50-15 or the Direzza Star Spec at 195-55-15. The concern is the 195 50 15 that are on the car do rub slightly in the front whan the suspesion is fully compressed. I know this has been posted before but I could not find it.
soloecho2 is offline   Reply With Quote
Old 08-04-2009, 01:39 PM   #2
Tamago
Start another Oil Thread!
Tamago's Avatar
Drives: ZZW30
in that size, the star spec is a better choice.
if you go up in size a bit, you can find offerings from many other companies (205 50 15 is the most common 15" tire as it's a good honda size)
i recommend looking at 205 50 or 205 55 if you care about overall diameter matching stock.
Originally Posted by xnamerxx
you nailed it sir.
Old 08-04-2009, 01:41 PM   #3
Loren
What?
Loren's Avatar
Drives: 2007 Yaris LB
Depends on what your split in "dual purpose" is. The DZ101 is closer to an all season tire, though it is a very good one. My wife has those on her MINI Cooper. If you expect to drive in a great deal of rain, or ANY snow, they would be the better bet.
The Star Spec is by far the better performance tire. It's not bad in the rain, but I expect at about half-tread the DZ101 would be better. And the Star Spec should not even remotely be considered for "winter" use anywhere that actually has winter.
195/55-15's may rub slightly depending on wheel offset and alignment. Just barely, though. With 41 offset 15x7's, I didn't get any rubbing. With 38 offset 15x7's, I got a little. Not enough to worry about, though. Just the fender liner.
Best all-season tires for the Yaris? Rahxephon Wheels, Tires and Suspension Forum sponsored by The Tire Rack 33 03-17-2013 06:40 PM
tire noob question..what's the widest tire size can run on stock 15"s? detroiter Wheels, Tires and Suspension Forum sponsored by The Tire Rack 22 12-06-2011 09:44 AM
Newly installed 15" tires feel 'weird' kristan Wheels, Tires and Suspension Forum sponsored by The Tire Rack 20 04-24-2010 06:58 PM
Selling winter tires and low profile floor jack with 2 stands voodoo22 Canada 10 11-16-2009 09:12 PM
Why do all low profile tires have to be of high performance design? grampi Wheels, Tires and Suspension Forum sponsored by The Tire Rack 15 05-16-2007 01:23 AM
