Old 06-20-2019, 03:17 PM   #1
justanotherdrunk
Drives: .
speedometer calibration
the latest android maps update finally includes the speed and speed limits so i wanted to check the accuracy of the car vs the app
i guess 1 mph deviation at 80 is decent
red means toooo fast!
Old 07-09-2019, 01:55 AM   #2
toyotavios_11
Drives: Toyota Vios
GPS itself wont be accurate too
toyotavios_11 is offline   Reply With Quote
Old 07-09-2019, 01:37 PM   #3
ern-diz
ern-diz's Avatar
Drives: 2007 Liftback
Fun and interesting to look at.
On Instagram
On Wheelwell
#TeamWheelwell #ForTheBuild
Old 07-10-2019, 09:27 PM   #4
kevinj93
kevinj93's Avatar
Drives: 2013 NCP130
Here in Australia it will most likely be much more accurate that the speedometer. My speedometer shows 80 km/h at a GPS indicated 76 km/h. This agrees with the readings from the OBDII port using the Torque app.
Australian regulations say the speedometer must not show a speed lower than the correct speed, but may read high by up to 4% plus 4 km/h.
Does anyone know if it is actually possible to adjust the speedometer? The last time I touched a speedometer to recalibrate it was 20 years ago on a Jaguar. A previous owner had the trip meter repaired, and the repairer did not correctly reset the mechanical zero...
Old 07-10-2019, 09:43 PM   #5
NYC-SE
NYC-SE's Avatar
Drives: 2014 Yaris SE
Yes here too speedometers read higher than actual speed. Annoying. I can deal with a 1mph error (like OP shows and as I have verified on my own Yaris as well) but I've driven some cars where they were off by 4 mph or so. Really annoying. GPS is generally more accurate.
Old 07-19-2019, 06:10 AM   #6
pjon
Drives: Yaris Icon+ 1.33 vvti
Speedometers here in the U.K. may read up to 10% higher than actual. Never lower.
Thanks for posting the info. re G Maps speedometer. I didn't know it was finaly available. Now found in settings and activated.
pjon is offline   Reply With Quote
Old 07-20-2019, 02:26 PM   #7
justanotherdrunk
Drives: .
Old 10-08-2019, 06:12 AM   #8
hmsailor
Drives: 2015 yaris hatchback
mine is 2mph off. this is from actual speed radar.
hmsailor is offline   Reply With Quote
Inaccurate analog speedometer JudgeM DIY / Maintenance / Service 2 12-23-2014 06:00 PM
Analog Speedometer instead Digital Sesjusz DIY / Maintenance / Service 7 07-01-2014 11:42 AM
Tacho , Speedometer with fix on my car selimesen007 DIY / Maintenance / Service 0 07-11-2013 05:20 PM
Speedometer Calibration / DeMetrification CTScott DIY / Maintenance / Service 17 10-06-2012 09:00 PM
Speedometer calibration Stiv DIY / Maintenance / Service 1 04-07-2010 12:41 PM
Copyright ©2000 - 2019, vBulletin Solutions Inc.
