Old 03-19-2017, 05:20 AM   #1
Pinchlite
Drives: 2007 yaris HB
Conflicting answers-bolt size removal drum
I have read quite a few posts and get different answears as to what is the correct bolt size to remove drum.
I have NEW drums and want to use the bolts to back off the old drum...what is the exact/correct bolt size?
Thanks in advance.
P.S
Tapping and banging with hammer is NOT how I want to remove drum as suggested from some research.
Pinchlite is offline   Reply With Quote
Old 03-19-2017, 08:47 AM   #2
Do what many do and remove one from hood bracket.
Old 03-19-2017, 08:52 AM   #3
Pinchlite
Hood bracket????
Why not just get proper ones from store?
Do you know the size?
Old 03-19-2017, 08:55 AM   #4
M8 x 1.25
Takes 15 seconds to search this forum to find that. The bolts that secure the hood hinge are the same size and people (again mentioned on the site) will remove one if they find drums ate stuck. Of course you put it back when done.
Old 03-19-2017, 08:57 AM   #5
Pinchlite
M8 x 1.25
M8 x 1.25
Perfect!
Thanks.
Old 03-19-2017, 11:08 AM   #6
bronsin
bronsin's Avatar
Originally Posted by Pinchlite View Post
Hood bracket????
Why spend money at the store?
Old 03-19-2017, 12:48 PM   #7
Pinchlite
Okay I will remove 1 from each side and see how it goes.
Wont be till next weekend though.
Off topic:
I have read that I may need to back off shoes as this these could get caught in the grooves in the drum causing removal problem/s?
Parking brake will be OFF of course.
Old 03-19-2017, 01:11 PM   #8
tmontague
tmontague's Avatar
I've never backed off the shoes as I found it hard to do with the drum still installed since that little "window" behind the shoes with the rubber plug in it is so small and you cannot see what you're doing.
I've just air chiseled the drum off and every time I remove it I take my air grinder and grind down the lip that is created so I don't have that issue in the future.
Old 03-19-2017, 01:33 PM   #9
Pinchlite
Grind down the lip??
I think what some are referring to is the shoes themselves binding on a groove on the inside wall of the drum.
Remeber new drums are going on aswell.
Old 03-19-2017, 01:34 PM   #10
Why? Don't complicate your life.
Have you confirmed that your drums are indeed stuck, or just speculating that they probably will be?
Old 03-19-2017, 01:36 PM   #11
Pinchlite
The front suspension stabilizer bar link nuts were very tight,but the muffler flange bolts came off real easy?
I am just assuming because of high mileage and being a Canadian driven car.
Old 03-19-2017, 02:00 PM   #12
bronsin
bronsin's Avatar
Off topic:
Possibly but not necessarily. See how it goes.
In the top of the backing plate theres a rubber plug you can remove to insert a screwdriver to back off the brake shoe adjustment. Thats if the drum wont fit over the shoes.
good luck! tell us what happens!
Old 03-19-2017, 02:03 PM   #13
tmontague
tmontague's Avatar
Yes, that groove is more of a lip that is cause by brake dust, rust and wear and that is what the brake shoe tends to get caught up on when trying to remove the drums. If the drums were being re used you can grind that lip down to make your life easier next time you try and remove the drums and adjust the shoes.
In your case you are installing new drums so that doesn't matter
Old 03-19-2017, 04:21 PM   #14
Pinchlite
Just what I needed to know...thanks.
Hopefully the shoes are still good or I will replace same time.
Just need to figure what brand is good.Some have mentioned raybestos.
Bolt Thread Size 4 Brake Drum Removal BobTheYaris DIY / Maintenance / Service 5 08-17-2014 01:14 PM
