Old 08-13-2016, 06:35 PM   #1
jaybowblue
Drives: 2007 yaris
Oil and coolant leak
Hello, I'm having a coolant and oil leak, both leaks appear to be coming from the engine. I had my headgasket and water pump replaced a couple months ago. I noticed the oil leak almost immediately after the job, the guys who did it came over and siliconed portions of the engine. (mainly the back of the engine towards the passenger side). I just took the car to the shop. and they said there was a bolt missing on that side in the same portion of the engine they applied silicon and that is where the coolant is coming from. The guy at the shop showed me the general area of the engine the bolt is missing (as mentioned before, in the back towards the passenger side) but I should have felt back behind the engine with them to get an exact location because now i can't find it. Does anyone have a diagram that could help? Could this missing bolt explain the coolant and the oil leak?
jaybowblue is offline   Reply With Quote
Old 08-14-2016, 10:41 PM   #2
jaybowblue
Drives: 2007 yaris
found the missing bolt, had it put in, it was no problem, not sure why the shop freaked out about it and refused to put another one in there.
Tags
anti-freeze, coolant, leak, oil
***The Engine Oil Bible*** Hussain-Vtec Performance Modifications 20 09-28-2016 02:47 PM
Fan not hooked up correctly making coolant leak? Mimm DIY / Maintenance / Service 3 11-17-2014 06:54 AM
Question replacing head gasket. Snyprwlf47 DIY / Maintenance / Service 3 07-13-2014 11:17 PM
