Old 02-27-2018, 10:16 PM   #1
dbrear
Drives: 2008 Yaris Liftback
Barometric Pressure Sensor on 1NZ-FE?
While playing around with some other diagnostics on a real-time ODB-II scanner, I found a barometric pressure reading. Where is the sensor that's measuring barometric pressure? I've been looking for an hour and I don't see anything in the service manual. How is this value determined?
dbrear is offline   Reply With Quote
Old 02-27-2018, 10:56 PM   #2
SirDigby
Drives: 2007 yaris 3 door
it's going to be part of the MAF sensor most likely. it would be in the intake system, and that is the only sensor...
DIY Oil Pressure Gauge Install LtNoogie DIY / Maintenance / Service 13 11-20-2009 04:13 PM
Check your air pressure! YarisOwnersDad Fuel Economy Forum 23 10-26-2009 09:30 AM
screw more psi in the tires. thebarber Fuel Economy Forum 43 05-04-2009 04:46 PM
