Old 05-19-2019, 07:51 AM   #1
Oli4
Drives: 01 yaris
01 Yaris Windscreen washer
Hi folks.
I have a 01 yaris (which goes and looks really well) however the windscreen washer front and back stopped working..
When I press the lever to get a water spray there is no sound from the motor.
Q: Any ideas what might be the problem ?
Thanks in advance for help.
Oli4 is offline   Reply With Quote
Old 05-19-2019, 01:02 PM   #2
johnwk
Drives: 2010 Yaris LB
Because the motor isn't making noise, it is probably an electrical issue, so I would check the fuses first. The owner's manual should indicate where to find the fuses and which ones are for the wipers. If the fuses are blown, then replacing them may fix the problem, and doing so is very cheap and easy. You can tell that they're blown if the filament inside the colored portion is broken into two pieces.
If the fuses are good, then the problem is likely in the wiring or the motors, which will be a bit more complicated to check and fix. But check the fuses first.
johnwk is offline   Reply With Quote
Old 05-19-2019, 02:58 PM   #3
Oli4
Drives: 01 yaris
Thanks for reply..
I will check that tomorrow.
Old 05-20-2019, 03:43 PM   #4
Oli4
Drives: 01 yaris
I had a look at the fuse today...It appears the wiper and washer have the same fuse...
It looks like it might be another problem (hopefully something simple.
Any ideas
Old 05-20-2019, 05:13 PM   #5
stykerdk
Yaris Hybrid Limited 2015
Drives: yaris Hybrid limited 2015
Maybe the washer motor is bad, it is a Dual outlet i some of the old Yaris.
https://www.ebay.de/itm/TWIN-OUTLET-...6224%7Ciid%3A1
https://www.ebay.co.uk/itm/1999-TOYO...368c%7Ciid%3A1
C-HR 1,8 Hybrid premium 2020
stykerdk is offline   Reply With Quote
DIY Cruise Control FAQ (2006-2010 Yaris) CTScott DIY / Maintenance / Service 467 10-18-2022 10:20 AM
04 yaris washer hose alex22808 DIY / Maintenance / Service 1 01-04-2016 04:03 PM
Vacationed in Italy - Brought home a D4D diesel Yaris CTScott Photo-Video-Media Gallery 19 07-26-2012 03:13 AM
