Old 01-27-2018, 07:06 PM   #1
Drummy
Drummy's Avatar
Drives: 2008 Toyota Yaris Hatch
Micro Image SSK
So I received my Short Shift kit except there is one problem with my yaris.
My shift cable disconnects, but not the rubber insert that is on the transmission lever on the post that the short shift gets connected to. Because of this I can't install it. Any tips on what I can do? I am going to get some Aero Kroil to hopefully loosen it up.
Drummy is offline   Reply With Quote
Old 01-27-2018, 11:39 PM   #2
tmontague
tmontague's Avatar
Post up a picture so I know exactly what part you're talking about. I don't remember a rubber part being , however I installed mine a while ago.
What ssk did you get? MI has 3 different ssk's, 2 under hood and one in cabin kit
I like to drive a slow car fast...
tmontague is online now   Reply With Quote
Old 01-28-2018, 10:34 PM   #3
Drummy
Drummy's Avatar
Taken from another post here in yaris world, the piece underneath the washer and cotterpin. That piece is stuck and won't come off.
The cable itself comes off, but not the piece it's connected to.
I got the kit with the in-engine short shift and the shift cable bracket.
Old 01-29-2018, 11:39 PM   #4
SirDigby
Drives: 2007 yaris 3 door
there should not be any issues removing the shifter cable. you may have some other issues...
Old 01-30-2018, 09:58 AM   #5
tmontague
tmontague's Avatar
I don't remember having to remove anything else underneath the washer. I'm pretty sure the ssk mounts right to the that piece underneath the washer
Old 01-31-2018, 10:11 AM   #6
Drummy
Drummy's Avatar
So to give a bit more information, underneath the washer and cotter pin, as seen in the picture above, there is a rubber insert that the Shift Cable End is attached to. When I pull up on the shift cable end, the plastic piece disconnects, but not the rubber piece that the end goes over, leaving a hole in the shift cable end about the size of the washer. Because of this, there is not enough space on the peg to place the short shifter on. I was going to put some PB Blaster on it to loosen the connection but did some research on it and found that rubber does not mix well with PB Blaster. I'm going to buy a can of Kroil on my next paycheck unless someone can come up with a solution.
I've already tried using Fluid Film and WD40 to weaken the connection between the rubber and the peg to no avail. If anyone can assist me in getting this figured out it would be greatly appreciated. I will update with pictures later today or tomorrow as I am at work right now. I'll see if I can get some pictures on my phone.
Old 01-31-2018, 01:11 PM   #7
tmontague
tmontague's Avatar
Use a small narrow pick to pry some air gap between the rubber and the peg and then use some silicone lube with a straw to spray in the gap. This should help loosen it up
Old 01-31-2018, 02:58 PM   #8
Drummy
Drummy's Avatar
I will attempt it. Any good silicone lube brands you can recommend?
Old 01-31-2018, 03:42 PM   #9
tmontague
tmontague's Avatar
I've always used Canadian tire in house brand and have been happy with it
Old 02-01-2018, 10:46 PM   #10
SirDigby
what you need is a hose spreader. it looks like a large "outside" snap ring pliers with a fork at the end.
a small angled pry bar.
maybe a threaded brake pad tool.
an angled body panel tool.
a ball joint tool.
a steering wheel puller.
a gear puller.
you can borrow a lot of these from autozone, advanced auto, o'rilly's, etc.
Old 02-02-2018, 08:12 PM   #11
Drummy
Drummy's Avatar
Assuming I would use them to pry it off the peg?
Old 02-02-2018, 11:09 PM   #12
ezhacker1
ezhacker1's Avatar
Drives: Decepticon - Ravage
did you try shifting the car in different gears first to see if you can get more wiggle room? I cant remember if i even popped what you are referring to off when i did it back then.
also did you get the bracket as well? it will help to move the linkage to a better angle.
Check out my Build thread:
Old 02-13-2018, 05:02 PM   #13
Drummy
Drummy's Avatar
So I got it installed with the bracket. I had to get my brake lines fixed as I was coming home from the bars ( I was the DD since I don't drink) and hit some nasty potholes that took out my brakes.
After my brakes were fixed I asked the guy if he could get the short shift installed and he said he would try. So the root of the problem was the brass bushing stuck on transmission lever was seized. Got that off, installed the part and bracket, and away we went. Brakes and all. Was pretty cheap too and I gotta say I LOVE IT! HOLY SHIT ITS SO NICE
Old 02-14-2018, 10:33 PM   #14
SirDigby
when i installed mine it felt chunky. it smoothed out after a few weeks. i sometimes still have issues with it grinding into first, but i think that is just how this trans is.
Old 04-01-2018, 12:27 PM   #15
vaironl
vaironl's Avatar
Drives: 2010 Yaris 3 door, manual tran
Sorry for being a little late to this reply but I installed it a couple of years ago and had the grinding issue, turns out the orientation matters so you might want to double check that. I never had grinding after properly orientating it.
vaironl is offline   Reply With Quote
FEELER/FS: MICRO IMAGE lowering springs. lets make a deal! sasquatch Items for Sale by private party 2 04-25-2012 07:14 PM
Micro Image lowering springs 1.8" drop markylicious Middle East 144 10-30-2011 01:18 AM
Micro Image Short Shift Kit- prototype review mazilla Performance Modifications 124 09-26-2011 06:04 PM
Micro Image meet Jan 30, 2010 Brian Photo-Video-Media Gallery 57 02-06-2010 11:27 PM
Mid-West Chapter Micro Image Car Club lilredrocket Southwest 10 10-05-2009 01:06 PM
Powered by vBulletin® Version 3.8.0
Copyright ©2000 - 2019, Jelsoft Enterprises Ltd.
