Old 12-02-2015, 01:11 PM   #1
StarWing
Drives: Yaris 1.3 VVTi 1st gen
AC issue
Hi, first post on this forum and immidiately a tech question.
My wife drives a 1st gen yaris (2004) and earlier this week the car went to the dealer for an airbag recall.
The job took about 1h to complete.
After this, the A/C wasn't working anymore. The compressor doesn't start (hearable) and the A/C control light doesn't come on.
I've checked the A/C fuse (7.5A) and the accessible connectors behind the fusebox and glovebox but they are all ok.
So, to be prepared for the discussion with dealer, could the malfuntioning of the AC be related to the actions regarding the recall ? I have no clue whatsoever about the technical details of the recall.
I also searched the internet for an electrical diagram of the A/C system, but I can't seem to find it. I found out that there should be an A/C control unit somewhere, but I found some conflicting info about the location of this box.
If this control box exists, where can I find it or other parts of the A/C system ? (relays, ...), and could it be that the control box was removed while working on the recall job ?
Thanks !!!
StarWing is offline   Reply With Quote
Old 12-02-2015, 09:20 PM   #2
Did they do something with the steering wheel or passenger airbag? If it was the passenger one, they would have had to remove the dashboard, so it is very possible that they forgot to put a connector back on. The most likely connectors would be the ones on the back of the control knobs for the AC system.
Here is the layout of AC parts under the dash:
Old 12-03-2015, 11:53 AM   #3
StarWing
Hi,
Thanks for the reply.
Appearantly they worked on the passenger side airbag, so it's likely that someting wasn't put back in the right place.
Stalling and restarting issue Yaris175 UK 6 02-12-2015 06:30 PM
Odd throttle issue mr_miles DIY / Maintenance / Service 21 11-01-2014 09:20 AM
yaris voltage issue yaris2010RS DIY / Maintenance / Service 11 12-29-2012 04:20 PM
08 HB DRL Issue BruceLee Cosmetic Modifications (Exterior/Interior) 3 02-18-2012 10:59 PM
heater control box issue DevilGirl DIY / Maintenance / Service 12 01-08-2010 03:45 PM
