Old 11-15-2014, 06:09 AM   #1
aeromarkuk
Drives: Yaris TR VVT-1
Ign off live feed problem/interior light, key and clock
Recently i seem to have lost the live feed when the ignition is off, I have noticed that the door courtesy light does not come on, it does come on however when the ign is on so door switch must be ok. In investigating this I have pulled each fuse individually to check and then replaced, now my wireless key lock wont work and I cant reprogram it as the door does not sense it is being opened with the key out (the reprogram method involves key in and out and door open and shut in a set sequence), I also seem to have disrupted the clocks ability to remember the time and every time I turn off the ign it resets to 12:00.
I have just checked all the fuses are in the correct place too.
Help!
aeromarkuk is offline   Reply With Quote
Old 11-15-2014, 06:34 AM   #2
Check the DOME fuse in the under bonnet fuse panel. If you only visually checked the fuses, try actually replacing that one, as the smaller rating fuses are not always visibly obvious that they have blown.
Old 11-15-2014, 07:56 AM   #3
aeromarkuk
Thanks. fuse checked ok, replaced anyway just now. Checked for permanent live feed to fuse location and is present with key out. No change.
Thanks.
Old 11-15-2014, 08:24 AM   #4
OK. The clock is also fed by the ACC fuse in the under dash fuse panel.
Logic for the door lock control is fed by the GAUGE fuse. The ECU-IG fuse feeds the body ECU for controlling the courtesy light.
Also, check your ground connection, particularly check the negative battery terminal to make sure it is not loose or corroded. If there is any corrosion on it, use a wire brush or sandpaper to clean the battery post and the inside of the terminal.
Old 11-16-2014, 11:21 AM   #5
aeromarkuk
Thanks again, been looking everywhere around the fuse box, where is the JB1 fuse location actually located? My panel is fuse layout is similar to this picture but I cant find the fuse locations ACC2, WIP-S at the top.
Old 11-16-2014, 11:22 AM   #6
aeromarkuk
the gauge and ECI-IG fuss are fine and the battery terminal good too, clean and greased.
Old 11-16-2014, 12:03 PM   #7
aeromarkuk
Old 11-16-2014, 12:03 PM   #8
aeromarkuk
Old 11-16-2014, 12:36 PM   #9
Can you get at the connector for the clock to measure the voltage on the wires to it?
